Date/Time: Sat, 19 Apr 2025 09:45:12 +0000
Request Volume Value Area Lines source
View Count: 123
[2025-03-07 21:23:32] |
JohnR - User831573 - Posts: 330 |
Support --> Thanks in advance for considering this request. In Studies2 there is source for a single bar, SCSFExport scsf_ValueAreaForBars(SCStudyInterfaceRef sc) Can you also provide source to the Volume Value Area Lines study? Or is it there already, and my search missed it? I want to take the source for the 'Volume Value Area Lines' study and not use it on a fixed lookback period. This would be the equivalent of a stripped down VBP tool for what I need. My issue with using the VBP tool is that each time I would need to call it, it will create a new instance of the study VBP. Using this tool it is only 3 subgraphs in one instance of the study, that draws the equivalent of many VBP tools. Way more efficient. A different solution would be for another API similar to sc.GetPointOfControlAndValueAreaPricesForBar for multiple bars. If any others have a study that does this -> calculate a VBP for multiple bars, so I can get POC, VAH and VAL, that is all I need. I would be grateful for any one to share. JohnR |
[2025-03-07 23:32:34] |
John - SC Support - Posts: 39362 |
The Volume Value Area Lines source code is not available.
[2025-03-18 15:31:22] |
coachted - Posts: 389 |
I am running a 1 minute chart set as a TPO chart with a a volume by price study set for 5 days...and it says the point of control is 5667.25 but if i run the volume value lines study on a 1 minute chart and set it to 5 days i am getting a point of control of 5672...I cant figure out why these are different, both charts are set with the same time settings
[2025-03-18 17:19:22] |
Please get us those two charts in their own Chartbook. Follow the instructions at the following link, but get us 2 charts, not just one: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
