Date/Time: Mon, 21 Apr 2025 04:41:24 +0000
ABVDIFF multiply by price to have Volume diff in USD
View Count: 66
[2025-03-07 19:08:51] |
vphienboupha - Posts: 1 |
Hi, Is ABVDIFF only the diff of volume, or volume x price? Any idea of how to get it, so we can have the amount in USD of the difference between buyers and sellers pressure, instead of volume which doesn't make sense when adding it for all stocks together. Thank you |
[2025-03-07 19:12:17] |
John - SC Support - Posts: 39362 |
For an explanation of ABVDIFF (and all the other statistics) refer to the following: Sierra Chart Market Statistics: Symbols If what you are looking for is not part of our Market Statistics (which we do not think it is) then we do not have what you are looking for. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
