Date/Time: Mon, 21 Apr 2025 04:41:23 +0000
renewed and the data will not contect
View Count: 54
[2025-03-07 19:03:19] |
miker - Posts: 8 |
the SC platform is green however I added teton and the system will not bring in the data
[2025-03-07 19:03:47] |
John - SC Support - Posts: 39362 |
Please get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
