Date/Time: Wed, 16 Sep 2026 15:32:42 +0000
Placement of Equity Option Symbol:
View Count: 1362
| [2014-09-23 20:57:56] |
| User22591 - Posts: 133 |
For trading options you suggested the option symbol should be placed in the chart setting window under symbol. Will this create a link to the specified chart and allow me to trade using the Dom or chart window attached or unattached?
| [2014-09-23 23:00:19] |
So did you want to chart a particular underlying symbol for the option and then trade using the option. If so, because of the significant pricing difference we do not think this would work well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
