Date/Time: Mon, 21 Apr 2025 04:38:25 +0000
Am I using Tick data and Teton Order Routing Service?
View Count: 95
[2025-03-06 16:30:51]
Fisheep - Posts: 5
Hi SC team,
I have just figured out all payments and basic setting as below:
1. Paid Service Package 11 - Integrated Advanced (Monthly)
2. Paid CME non-professional top-of-book
3. Set Current Selected Service: SC Data - All Service
4 Set Symbol: ESH25-CME
5. Set Mode: Trade Simulation Mode On
I have noticed that my chart is real time successfully.
But I have a final silly question.
Am I using tick data and also Teton Order Routing Service quality now?
Or you can check my account is running alright?
Million thanks
Fisheep
[2025-03-06 16:38:31]
John - SC Support - Posts: 39362
Since you are connected to "SC Data", if you are getting real-time data (which you should be per your account setup) then you are getting the only quality of data we have.
But, there is a setting on your end that controls whether the data is stored at the Per Tick level or not. Refer to the following, you want this to be set to "1 tick" if that is how you want your data:
Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings)
