Date/Time: Wed, 19 Mar 2025 02:39:51 +0000
Delayed data feed
View Count: 49
[2025-03-06 15:30:03] |
User884726 - Posts: 8 |
Please can I find out why I have a delayed data feed?
[2025-03-06 16:09:28] |
John - SC Support - Posts: 38782 |
Everything looks good on your account at this time. If you are still having an issue, then get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
