Date/Time: Mon, 21 Apr 2025 04:38:31 +0000
Observations ref charts
View Count: 60
[2025-03-06 15:29:19] |
User862138 - Posts: 25 |
Good day - been using SCs for a long time and very happy with it. I also use charts from Track n Trade and the following with these charts are very nice (maybe something that SC could look at or consider and I think it can make SC even better). 1. Right click on the chart and one can move the chart anywhere on the screen - the indicators/studies all follow. 2. The cursor on the TnT charts has a down-line to time and line to the right to price only. Could be very nice if SC has the function where one could choose this function and also if it should be a solid/dash/dot etc line. Just some observations. Best regards |
[2025-03-06 16:08:30] |
John - SC Support - Posts: 39362 |
Both of these are available in Sierra Chart. Although we are not certain of exactly what you are looking for with #1, as there are multiple ways to move the chart around. But refer to the following in particular: Chart Drawing Tools: Hand And refer to the following for the crosshairs (you can change the crosshair style and color in the Graphics Settings): Chart Drawing Tools: Chart Values/Crosshair For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
