Date/Time: Mon, 21 Apr 2025 04:50:12 +0000
2 charts connection by Price
View Count: 63
[2025-03-06 10:12:44] |
User904434 - Posts: 63 |
Can I connect 2 charts ES and MES (diffrent symbol) - with the same price
[2025-03-06 15:50:44] |
John - SC Support - Posts: 39362 |
We do not understand what you are trying to do. One thing we think you may be asking is that you can link two different charts to have the same Vertical Scale, so as one is moved the other will move as well. Refer to the following: Chart Settings: Chart Linking >> Vertical Scale (Chart >> Chart Settings >> Linking menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
