Date/Time: Mon, 21 Apr 2025 04:35:49 +0000
Qty and Price Window
View Count: 167
[2025-03-06 08:39:05]
nicktrader - Posts: 748
plc see pic. The window has recently become quite small. I always have to enlarge it.
imageQty and Price Window.png / V - Attached On 2025-03-06 08:38:51 UTC - Size: 5.23 KB - 36 views
[2025-03-06 08:43:46]
Sierra_Chart Engineering - Posts: 19285
We are checking on this.
[2025-03-06 08:46:27]
We do not see an issue with this window. You can adjust the size of it by left clicking at the lower right of it and making it larger.
Date Time Of Last Edit: 2025-03-06 08:46:38
[2025-03-06 16:38:18]
Making the window larger is not the problem.
If I restart the platform, the window is smaller again and I have to make it larger again...
[2025-03-06 16:43:45]
The window is also smaller again if I set a new order without restarting and want to adjust the quantity again.
In previous versions, the window was always larger.
[2025-03-06 22:34:26]
Adjust the width of the Value column. Make it larger.
We will also make a code change related to this.
Date Time Of Last Edit: 2025-03-06 22:38:57
[2025-03-07 09:36:07]
BTW: Even if I make the column larger, the next time I open it, it will be restored to its narrow state.
Many thanks
Date Time Of Last Edit: 2025-03-07 09:37:00
[2025-03-10 07:43:58]
Window Size perfect.
Many thanks
