Date/Time: Fri, 20 Sep 2024 05:27:57 +0000
AMP Demo with Rithmic
View Count: 1327
[2014-09-23 16:51:25] |
User78442 - Posts: 260 |
Can't connect. I will send a log; Software version: 1192 | 2014-09-23 16:40:58 Usage end date: 2014-10-08 | 2014-09-23 16:40:58 Enabled for: Advanced Features. | 2014-09-23 16:40:58 Enabled for: Advanced Features 2. | 2014-09-23 16:40:58 Enabled for: Sierra Chart Historical Data Service. | 2014-09-23 16:40:58 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-09-23 16:40:58 Active service: SC Forex Data (FXCM) | 2014-09-23 16:40:58 Time Zone: +00:00:00 (UTC+00) | 2014-09-23 16:40:58 2014-09-23 17:40:58 Local computer clock time | 2014-09-23 16:40:58 2014-09-23 16:40:58 GMT time | 2014-09-23 16:40:58 2014-09-23 16:40:58 Time zone adjusted time | 2014-09-23 16:40:58 Time difference to server time: 1 seconds. | 2014-09-23 16:40:58 Program path: C:\SierraChart\ | 2014-09-23 16:40:58 Data Files path: C:\SierraChart\Data\ | 2014-09-23 16:40:58 OS Version Number: 6.1 | 2014-09-23 16:40:58 Checking for new symbol settings for fxcm | 2014-09-23 16:40:58 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-09-23 16:40:58 HTTP connection to www.sierrachart.com:80 (1052) | Connected. | 2014-09-23 16:40:58 Requesting symbol settings for fxcm. Overwrite = on. | 2014-09-23 16:40:58 Symbol settings received. | 2014-09-23 16:40:59 Processed received symbol settings | 2014-09-23 16:40:59 SC Forex Data (FXCM) | Connecting to the server ds5.sierracharts.com. Port 443 | 2014-09-23 16:41:03 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-09-23 16:41:03 Socket (1592) | Connected. | 2014-09-23 16:41:03 SC Forex Data (FXCM) | Connected to server. | 2014-09-23 16:41:03 SC Forex Data (FXCM) | Sending logon request message. | 2014-09-23 16:41:03 SC Forex Data (FXCM) | Server Info - Server Name: . | 2014-09-23 16:41:03 SC Forex Data (FXCM) | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-23 16:41:03 SC Forex Data (FXCM) | Successfully connected. | 2014-09-23 16:41:03 HTTP connection to www.sierrachart.com:80 (1052) | Closed. No error. | 2014-09-23 16:41:09 HTTP connection to www.sierrachart.com:80 (1052) | Shutdown and closed. | 2014-09-23 16:41:09 Current selected Data/Trading service: Rithmic Trading | 2014-09-23 16:44:35 Checking for new symbol settings for rim | 2014-09-23 16:44:35 Socket (1592) | Shutdown and closed. | 2014-09-23 16:44:35 SC Forex Data (FXCM) | Disconnected from the server. | 2014-09-23 16:44:35 Rithmic Trading | Port for executable: 65511 | 2014-09-23 16:44:35 Listening socket (1592), port 65511 | Closed. | 2014-09-23 16:44:35 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-09-23 16:44:35 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 188.40.121.148 | 2014-09-23 16:44:35 HTTP connection to www.sierrachart.com:80 (1592) | Connected. | 2014-09-23 16:44:35 Requesting symbol settings for rim. Overwrite = on. | 2014-09-23 16:44:35 Symbol settings received. | 2014-09-23 16:44:36 Processed received symbol settings | 2014-09-23 16:44:36 Rithmic Trading | Connecting to the server 127.0.0.1. Port 65511 | 2014-09-23 16:44:37 Socket (1648) | Connected. | 2014-09-23 16:44:37 Rithmic Trading | Connected to server. | 2014-09-23 16:44:37 Rithmic Trading | Sending logon request message. | 2014-09-23 16:44:37 Rithmic Trading | Starting the connection process to data and trading service. | 2014-09-23 16:44:37 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-09-23 16:44:37 Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-09-23 16:44:37 HTTP connection to www.sierrachart.com:80 (1592) | Closed. No error. | 2014-09-23 16:44:46 HTTP connection to www.sierrachart.com:80 (1592) | Shutdown and closed. | 2014-09-23 16:44:46 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-09-23 16:45:00 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-09-23 16:45:00 Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-09-23 16:45:00 Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-23 16:45:00 Rithmic Trading | Logon error from server | 2014-09-23 16:45:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:45:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:45:00 Socket (1648) | Shutdown and closed. | 2014-09-23 16:45:00 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:45:00 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:45:00 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:45:02 Rithmic Trading | Connecting to the server 127.0.0.1. Port 65511 | 2014-09-23 16:45:04 Socket (1584) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:45:05 Socket (1584) | Shutdown and closed. | 2014-09-23 16:45:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:45:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:45:05 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:45:05 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:45:05 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:45:08 Rithmic Trading | Connecting to the server 127.0.0.1. Port 65511 | 2014-09-23 16:45:10 Socket (1656) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:45:11 Socket (1656) | Shutdown and closed. | 2014-09-23 16:45:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:45:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:45:11 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:45:11 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:45:11 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:45:13 Rithmic Trading | Connecting to the server 127.0.0.1. Port 65511 | 2014-09-23 16:45:15 Socket (1592) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:45:16 Socket (1592) | Shutdown and closed. | 2014-09-23 16:45:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:45:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:45:16 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:45:16 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:45:16 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:45:18 Rithmic Trading | Connecting to the server 127.0.0.1. Port 65511 | 2014-09-23 16:45:20 Socket (1656) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:45:21 Socket (1656) | Shutdown and closed. | 2014-09-23 16:45:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:45:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:45:21 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:45:21 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:45:21 Rithmic Trading | Port for executable: 49166 | 2014-09-23 16:45:23 Listening socket (1668), port 49166 | Closed. | 2014-09-23 16:45:23 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-09-23 16:45:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49166 | 2014-09-23 16:45:25 Socket (1668) | Connected. | 2014-09-23 16:45:25 Rithmic Trading | Connected to server. | 2014-09-23 16:45:25 Rithmic Trading | Sending logon request message. | 2014-09-23 16:45:25 Rithmic Trading | Starting the connection process to data and trading service. | 2014-09-23 16:45:25 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-09-23 16:45:25 Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-09-23 16:45:25 Rithmic Trading | Server Alert: Market Data Connection Broken | 2014-09-23 16:46:12 Rithmic Trading | Server Alert: Trading System Connection Broken | 2014-09-23 16:46:33 Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-09-23 16:46:41 Rithmic Trading | Server Alert: PnL Connection Opened | 2014-09-23 16:46:41 Rithmic Trading | Server Alert: Trading System Connection Login Failed. Result text: "permission denied" | 2014-09-23 16:46:41 Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-09-23 16:46:41 Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-23 16:46:41 Rithmic Trading | Logon error from server | 2014-09-23 16:46:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:46:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:46:41 Socket (1668) | Shutdown and closed. | 2014-09-23 16:46:41 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:46:41 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:46:41 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:46:43 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49166 | 2014-09-23 16:46:45 Socket (920) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:46:46 Socket (920) | Shutdown and closed. | 2014-09-23 16:46:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:46:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:46:46 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:46:46 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:46:46 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:46:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49166 | 2014-09-23 16:46:50 Socket (1668) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:46:51 Socket (1668) | Shutdown and closed. | 2014-09-23 16:46:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:46:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:46:51 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:46:51 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:46:51 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:46:53 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49166 | 2014-09-23 16:46:55 Socket (920) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:46:56 Socket (920) | Shutdown and closed. | 2014-09-23 16:46:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:46:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:46:56 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:46:56 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:46:56 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:46:58 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49166 | 2014-09-23 16:47:00 Socket (1660) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:47:01 Socket (1660) | Shutdown and closed. | 2014-09-23 16:47:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:47:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:47:01 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:47:01 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:47:01 Rithmic Trading | Port for executable: 49200 | 2014-09-23 16:47:03 Listening socket (1592), port 49200 | Closed. | 2014-09-23 16:47:03 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-09-23 16:47:03 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49200 | 2014-09-23 16:47:05 Socket (1592) | Connected. | 2014-09-23 16:47:05 Rithmic Trading | Connected to server. | 2014-09-23 16:47:05 Rithmic Trading | Sending logon request message. | 2014-09-23 16:47:05 Rithmic Trading | Starting the connection process to data and trading service. | 2014-09-23 16:47:05 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-09-23 16:47:05 Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-09-23 16:47:05 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-09-23 16:47:07 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-09-23 16:47:07 Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-09-23 16:47:07 Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-23 16:47:07 Rithmic Trading | Logon error from server | 2014-09-23 16:47:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:47:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:47:07 Socket (1592) | Shutdown and closed. | 2014-09-23 16:47:07 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:47:07 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:47:07 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:47:09 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49200 | 2014-09-23 16:47:11 Socket (824) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:47:12 Socket (824) | Shutdown and closed. | 2014-09-23 16:47:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:47:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:47:12 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:47:13 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:47:13 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:47:15 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49200 | 2014-09-23 16:47:17 Socket (1592) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:47:18 Socket (1592) | Shutdown and closed. | 2014-09-23 16:47:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:47:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:47:18 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:47:18 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:47:18 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:47:20 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49200 | 2014-09-23 16:47:22 Socket (824) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 16:47:23 Socket (824) | Shutdown and closed. | 2014-09-23 16:47:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 16:47:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 16:47:23 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:47:23 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 16:47:23 Rithmic Trading | Bridge process is still running. | 2014-09-23 16:47:25 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49200 | 2014-09-23 16:47:27 File >> Disconnect selected. | 2014-09-23 16:47:27 Socket (1592) | Shutdown and closed. | 2014-09-23 16:47:27 Rithmic Trading | Disconnected from the server. | 2014-09-23 16:47:27 The above has been sent to support. | 2014-09-23 16:48:30 * Sending of the message log was completed. Please read the response that was received. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2014-09-23 16:48:30 |
[2014-09-23 17:06:19] |
User11942 - Posts: 298 |
Try to choose "Paper Trading Server" in "Connection details" box in Data/Trade service settings for demo connection. Then reconnect to the trading service. "Rithmic 01 US server" is for Live trading only and can't be used with demo credentials. http://www.sierrachart.com/index.php?page=doc/Rithmic.php#SetupInstructions |
[2014-09-23 17:25:06] |
This is the relevant error message: Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-09-23 16:47:07 Refer to this section here for help with this: http://www.sierrachart.com/index.php?page=doc/OptimusRithmic.php#ResolvingPermissionDenied Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-23 17:51:21] |
New error message; Rithmic Trading | Bridge process is still running. | 2014-09-23 17:45:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49953 | 2014-09-23 17:45:37 Socket (1716) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:45:38 Socket (1716) | Shutdown and closed. | 2014-09-23 17:45:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:45:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:45:38 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:45:38 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:45:38 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:45:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49953 | 2014-09-23 17:45:42 Socket (824) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:45:43 Socket (824) | Shutdown and closed. | 2014-09-23 17:45:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:45:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:45:43 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:45:43 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:45:43 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:45:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49953 | 2014-09-23 17:45:47 Socket (1716) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:45:48 Socket (1716) | Shutdown and closed. | 2014-09-23 17:45:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:45:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:45:48 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:45:48 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:45:48 Rithmic Trading | Port for executable: 49971 | 2014-09-23 17:45:50 Listening socket (812), port 49971 | Closed. | 2014-09-23 17:45:50 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-09-23 17:45:50 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49971 | 2014-09-23 17:45:52 Socket (812) | Connected. | 2014-09-23 17:45:52 Rithmic Trading | Connected to server. | 2014-09-23 17:45:52 Rithmic Trading | Sending logon request message. | 2014-09-23 17:45:52 Rithmic Trading | Starting the connection process to data and trading service. | 2014-09-23 17:45:52 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-09-23 17:45:52 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-09-23 17:45:52 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-09-23 17:45:54 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-09-23 17:45:54 Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-09-23 17:45:54 Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-23 17:45:54 Rithmic Trading | Logon error from server | 2014-09-23 17:45:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:45:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:45:54 Socket (812) | Shutdown and closed. | 2014-09-23 17:45:54 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:45:54 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:45:54 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:45:56 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49971 | 2014-09-23 17:45:58 Socket (1684) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:45:59 Socket (1684) | Shutdown and closed. | 2014-09-23 17:45:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:45:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:45:59 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:45:59 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:45:59 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:46:01 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49971 | 2014-09-23 17:46:03 Socket (1720) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:46:04 Socket (1720) | Shutdown and closed. | 2014-09-23 17:46:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:04 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:04 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:04 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:46:06 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49971 | 2014-09-23 17:46:08 Socket (1684) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:46:09 Socket (1684) | Shutdown and closed. | 2014-09-23 17:46:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:09 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:09 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:09 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:46:11 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49971 | 2014-09-23 17:46:13 Socket (896) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:46:14 Socket (896) | Shutdown and closed. | 2014-09-23 17:46:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:14 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:14 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:14 Rithmic Trading | Port for executable: 49989 | 2014-09-23 17:46:16 Listening socket (824), port 49989 | Closed. | 2014-09-23 17:46:16 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-09-23 17:46:16 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49989 | 2014-09-23 17:46:18 Socket (824) | Connected. | 2014-09-23 17:46:18 Rithmic Trading | Connected to server. | 2014-09-23 17:46:18 Rithmic Trading | Sending logon request message. | 2014-09-23 17:46:18 Rithmic Trading | Starting the connection process to data and trading service. | 2014-09-23 17:46:18 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-09-23 17:46:18 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-09-23 17:46:18 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-09-23 17:46:20 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-09-23 17:46:21 Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-09-23 17:46:21 Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-23 17:46:21 Rithmic Trading | Logon error from server | 2014-09-23 17:46:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:21 Socket (824) | Shutdown and closed. | 2014-09-23 17:46:21 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:21 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:21 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:46:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49989 | 2014-09-23 17:46:25 Socket (1664) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:46:26 Socket (1664) | Shutdown and closed. | 2014-09-23 17:46:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:26 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:26 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:26 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:46:28 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49989 | 2014-09-23 17:46:30 Socket (1668) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:46:31 Socket (1668) | Shutdown and closed. | 2014-09-23 17:46:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:31 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:31 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:31 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:46:33 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49989 | 2014-09-23 17:46:35 Socket (1664) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:46:36 Socket (1664) | Shutdown and closed. | 2014-09-23 17:46:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:36 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:36 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:36 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:46:38 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49989 | 2014-09-23 17:46:40 Socket (1668) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:46:41 Socket (1668) | Shutdown and closed. | 2014-09-23 17:46:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:41 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:41 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:41 Rithmic Trading | Port for executable: 50005 | 2014-09-23 17:46:43 Listening socket (1656), port 50005 | Closed. | 2014-09-23 17:46:43 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-09-23 17:46:43 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50005 | 2014-09-23 17:46:45 Socket (1656) | Connected. | 2014-09-23 17:46:45 Rithmic Trading | Connected to server. | 2014-09-23 17:46:45 Rithmic Trading | Sending logon request message. | 2014-09-23 17:46:45 Rithmic Trading | Starting the connection process to data and trading service. | 2014-09-23 17:46:45 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-09-23 17:46:45 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-09-23 17:46:45 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-09-23 17:46:48 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-09-23 17:46:48 Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-09-23 17:46:48 Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-23 17:46:48 Rithmic Trading | Logon error from server | 2014-09-23 17:46:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:48 Socket (1656) | Shutdown and closed. | 2014-09-23 17:46:48 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:48 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:48 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:46:50 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50005 | 2014-09-23 17:46:52 Socket (1056) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:46:53 Socket (1056) | Shutdown and closed. | 2014-09-23 17:46:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:53 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:53 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:53 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:46:55 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50005 | 2014-09-23 17:46:57 Socket (1656) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:46:58 Socket (1656) | Shutdown and closed. | 2014-09-23 17:46:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:46:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:46:58 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:46:58 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:46:58 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:47:00 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50005 | 2014-09-23 17:47:02 Socket (812) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:47:03 Socket (812) | Shutdown and closed. | 2014-09-23 17:47:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:03 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:03 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:03 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:47:05 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50005 | 2014-09-23 17:47:07 Socket (1716) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:47:08 Socket (1716) | Shutdown and closed. | 2014-09-23 17:47:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:08 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:08 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:08 Rithmic Trading | Port for executable: 50025 | 2014-09-23 17:47:10 Listening socket (1664), port 50025 | Closed. | 2014-09-23 17:47:10 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-09-23 17:47:10 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50025 | 2014-09-23 17:47:12 Socket (1664) | Connected. | 2014-09-23 17:47:12 Rithmic Trading | Connected to server. | 2014-09-23 17:47:12 Rithmic Trading | Sending logon request message. | 2014-09-23 17:47:12 Rithmic Trading | Starting the connection process to data and trading service. | 2014-09-23 17:47:12 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-09-23 17:47:12 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-09-23 17:47:12 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-09-23 17:47:14 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-09-23 17:47:14 Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-09-23 17:47:14 Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-23 17:47:14 Rithmic Trading | Logon error from server | 2014-09-23 17:47:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:14 Socket (1664) | Shutdown and closed. | 2014-09-23 17:47:14 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:14 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:14 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:47:16 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50025 | 2014-09-23 17:47:18 Socket (1724) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:47:19 Socket (1724) | Shutdown and closed. | 2014-09-23 17:47:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:19 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:19 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:19 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:47:21 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50025 | 2014-09-23 17:47:23 Socket (1664) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:47:24 Socket (1664) | Shutdown and closed. | 2014-09-23 17:47:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:24 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:24 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:24 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:47:26 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50025 | 2014-09-23 17:47:28 Socket (1720) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:47:29 Socket (1720) | Shutdown and closed. | 2014-09-23 17:47:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:29 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:29 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:29 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:47:31 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50025 | 2014-09-23 17:47:33 Socket (1684) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:47:34 Socket (1684) | Shutdown and closed. | 2014-09-23 17:47:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:34 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:34 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:34 Rithmic Trading | Port for executable: 50042 | 2014-09-23 17:47:36 Listening socket (812), port 50042 | Closed. | 2014-09-23 17:47:36 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-09-23 17:47:36 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50042 | 2014-09-23 17:47:38 Socket (812) | Connected. | 2014-09-23 17:47:38 Rithmic Trading | Connected to server. | 2014-09-23 17:47:38 Rithmic Trading | Sending logon request message. | 2014-09-23 17:47:38 Rithmic Trading | Starting the connection process to data and trading service. | 2014-09-23 17:47:38 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-09-23 17:47:38 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2014-09-23 17:47:38 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-09-23 17:47:40 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-09-23 17:47:41 Rithmic Trading | Server Info - Server Name: DTC Bridge. | 2014-09-23 17:47:41 Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-09-23 17:47:41 Rithmic Trading | Logon error from server | 2014-09-23 17:47:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:41 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:41 Socket (812) | Shutdown and closed. | 2014-09-23 17:47:41 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:41 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:41 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:47:43 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50042 | 2014-09-23 17:47:45 Socket (1720) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:47:46 Socket (1720) | Shutdown and closed. | 2014-09-23 17:47:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:46 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:46 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:46 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:47:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50042 | 2014-09-23 17:47:50 Socket (812) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:47:51 Socket (812) | Shutdown and closed. | 2014-09-23 17:47:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:51 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:51 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:51 Rithmic Trading | Bridge process is still running. | 2014-09-23 17:47:53 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50042 | 2014-09-23 17:47:55 Socket (1720) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-09-23 17:47:56 Socket (1720) | Shutdown and closed. | 2014-09-23 17:47:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-09-23 17:47:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-09-23 17:47:56 Rithmic Trading | Disconnected from the server. | 2014-09-23 17:47:56 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-09-23 17:47:56 |
[2014-09-23 18:12:28] |
We see nothing different here. We are still seeing this: Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-09-23 17:47:41 That is the relevant message. Everyone gets a permission denied error from Rithmic. Very common problem. Once again refer to the documentation we linked to previously. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
