Date/Time: Mon, 21 Apr 2025 04:44:11 +0000
No symbols visible, and no data as a result
View Count: 127
[2025-03-05 18:37:35]
User710890 - Posts: 25
Hello, after a power outage I am no longer receiving data, I guess because no symbols are present. When I open Global Settings->Symbol Settings, no symbols are present. "Use Custom Symbol Settings Values" is not checked, and I have deleted the custom symbol settings file as an extra measure. When I click Update From Server, the log shows that symbols were requested and received, yet nothing is updated. I have also updated to the latest version of Sierra, and have restarted it multiple times after trying to update symbol settings.
Please advise at your earliest convenience.
Private File
imageFind Symbol.png / V - Attached On 2025-03-05 18:31:56 UTC - Size: 11.33 KB - 19 views
imageSymbol Settings.png / V - Attached On 2025-03-05 18:32:01 UTC - Size: 21.25 KB - 18 views
[2025-03-05 19:13:01]
colin0021 - Posts: 29
this problem appears to be common. I'm having the same issue.
imageScreenshot_3.jpg / V - Attached On 2025-03-05 19:12:45 UTC - Size: 589.58 KB - 17 views
[2025-03-05 20:07:33]
I'm updating this thread to say that after a while I opened Sierra Chart back up and it appears that things are working again. I didn't do anything else on my end to try to fix things in the meantime.
[2025-03-05 22:18:38]
John - SC Support - Posts: 39362
There was a change made to the symbols on the back-end that caused this. If you are still having a problem then download the symbols by following these instructions:
Global Symbol Settings: Update Symbol Settings
We apologize for the inconvenience.
[2025-03-06 14:56:20]
John, after I tried what you showed, now SC works. Thanks.
