Date/Time: Mon, 15 Dec 2025 09:11:41 +0000
OHLC
View Count: 240
[2025-03-05 17:52:08]
User841161 - Posts: 315
Why does the Daily OHLC Study appear to be off? The daily low is showing lower than daily low?
image3-5-25.PNG / V - Attached On 2025-03-05 17:51:57 UTC - Size: 115.33 KB - 89 views
[2025-03-05 19:37:20]
John - SC Support - Posts: 43443
You are displaying the data as a "Line on ...". That line is not set to be either the High or Low, therefore the Daily OHLC will not touch it at either end. If you display bars, you will see that the study is correct.
