Date/Time: Mon, 21 Apr 2025 04:50:14 +0000
Active PL displayed on stops as being moved
View Count: 49
[2025-03-05 13:31:06] |
UserTLE - Posts: 8 |
Hello I had lost all my setting and reset everything up, and I am faaairly certain I used to have this set up... Currently if I am in a position, my stop and limit are in place, they display the P/L of that level in the line box on the chart, the price, and points achieved if we go to that level. At the moment, if I click on my stop and drag it around, price will update in real time as I drag it around. The P/L however does not update as I drag the stop or limit around like price does, it will only update once I click again to release the stop (or limit) and set it in place. I am pretty sure this used to work, and I liked seeing the projected P/L as I moved the stop around. I know its very nit picky... Any idea how to do this? |
[2025-03-05 18:41:41] |
John - SC Support - Posts: 39362 |
Refer to the following: Global Trade Settings Windows: Attached Order P/L When Modifying (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
