Date/Time: Mon, 21 Apr 2025 04:47:17 +0000
Inquiry on Combining Ticks in Market Depth Display
View Count: 97
[2025-03-05 13:30:30] |
User990777 - Posts: 17 |
Hi Support, Good day to you. I am currently using the GC symbol, and in my Trade >> "Show Market Data Columns", I can see 100 levels at bid and 100 levels at ask. Question: Is it possible to combine 2 ticks into 1 level so that within the 100 levels, I can display up to 200 ticks (if each level represents 2 ticks)? I tried adjusting the setting in Chart >> Chart Settings >> Market Depth >> "Market Depth Combine Increment in Ticks" to 2, but the depth did not increase to 200 ticks as expected. My intention is to extend the displayed price levels to 200 ticks within the 100 levels. Could you confirm if this is possible? If so, could you guide me on the correct settings to achieve this? Many thanks in advance for your support. |
[2025-03-05 15:25:33] |
Sierra_Chart Engineering - Posts: 19285 |
You need to adjust this setting to 200: Sierra Chart Server Settings: Max Depth Levels (Global Settings >> Sierra Chart Server Settings >> General >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
