Date/Time: Fri, 20 Sep 2024 05:41:11 +0000
linked values scales
View Count: 1511
[2014-09-23 16:01:42] |
User57210 - Posts: 121 |
Hello, I would like to be able to link multiple charts value scales. Specifically, I am setting them all to a fixed scale with no auto-centering or centering of any kind, and when I drag to move the scale up and down, I need this to happen for other charts that I have set to the same fixed scale. I hope this makes sense. I'll lay it out in another way: I have two charts side by side. I go through and set them both to fixed scale, and then I actually drag the scales to line them up (so that when I use a crosshair I'm referencing the same visual levels on both charts seamlessly). I don't need both value scales, so I hide the value scale on the leftmost chart. Prices change, so I eventually need to drag the value scale up or down to accommodate new highs/lows. I would then have to go in, unhide the left chart value scale, and drag it to precisely match the chart on the right. I need to be able to link these charts so that they automatically have the same value scales. Thank you. |
[2014-09-23 19:38:22] |
This is not supported.
[2014-09-23 19:40:18] |
Oh wow, I hadn't noticed that. I guess I'll open a support ticket and request that it BE SUPPORTED. -Paying user. |
[2014-09-23 19:53:57] |
Any request like this needs to be posted on our Support Board. Please do not use an account support ticket. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-23 20:05:11] |
What? http://i.imgur.com/Pqd4xp5.png This is the support board.... see screenshot. I am very confused by your "support" today. |
[2014-09-23 20:05:48] |
Are you refusing to even consider adding this option to Sierra Chart?
[2014-09-24 02:12:45] |
Right, this is the Support Board. However, you made reference to an Account Support Ticket which are different: https://www.sierrachart.com/usercp.php?page=SupportTickets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
