Date/Time: Mon, 15 Dec 2025 09:11:43 +0000
Depth of Market
View Count: 220
| [2025-03-05 08:03:56] |
| MajuroCapital - Posts: 6 |
Hello, I would like to set my DOM so that in the recent Bid/Ask columns I can simply see the large orders that have been executed. How can I set the quantity in the recent Bid/Ask? Thank you very much for your feedback and all your support. Best regards. |
| [2025-03-05 18:31:16] |
| John - SC Support - Posts: 43443 |
There is not an option to only display values greater than a certain level. You can, however, highlight levels that are greater than a certain value. Refer to the following: Chart Settings: Market Depth Highlight High Threshold Value (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
