Date/Time: Mon, 15 Dec 2025 09:28:36 +0000
merging profiles causing issues
View Count: 271
[2025-03-05 06:22:34]
William Cline - Posts: 22
tried merging 01;20;2025 with 01;21;2025 tpo profile and for some reason it stacked another profile directly on top of my merged profile, there's not value area on my merged profile and it made 01;22;2025 go missing from the chart.
https://www.sierrachart.com/image.php?Image=1741155511219.png
[2025-03-05 14:40:00]
John - SC Support - Posts: 43443
Please get us an image of the TPOs for that period without the merges. You can undo the merges by right-clicking on a TPO and selecting "Undo All Merges for This Chart".
[2025-03-05 15:30:43]
https://www.sierrachart.com/image.php?Image=1741188594104.png
[2025-03-05 19:08:19]
The data from 1/22 has been merged in with 1/20 and 1/21. It is not missing.
How exactly did you perform this merge? If you repeat it, do you get the same result?
