Date/Time: Tue, 15 Sep 2026 22:29:12 +0000
Did Study/Overlay Change in 1192? Incorrect Display
View Count: 1662
| [2014-09-23 15:52:48] |
| cmet - Posts: 742 |
I use Study/Overlay quite a bit and since I've updated to version 1192, it seems that the way overlays are displayed has changed. I am noticing 2 things: -The latest values are not being represented correctly in the overlay (they are either missing or innaccurate) -The overlay has missing areas (for example when overlaying a keltner channel that is filled, there are random blank spots where there is no fill). I also switched to the SC Real Time Feed. Not sure if this has any impact but was hoping to find out what's going on. Here is an image of a 1 minute chart with an overlay of Ask/Bid Volume Bars from a 6 tick PNF chart: http://postimg.org/image/fgjvdabyr/ Notice how on the values from Ask/Bid the 6 PNF are in the 8000 range. On the 1 minute chart (top) in the overlay there is one green bar and the rest of the values are not displayed. I believe that should at least be filled with the last value because I'm using these settings: http://postimg.org/image/ieehuc9qb/ Here is what the exact same charts look like in version 1187 (they are correct) http://postimg.org/image/p71j4o5lz/ |
| [2014-09-23 16:26:54] |
There were some changes to the study to support the study Subgraph Displacement setting and we will have to revert them because we can see it is causing problem.
| [2014-09-24 09:08:09] |
We need a simple test Chartbook to duplicate this problem. We are going to revert the changes for now because this is something that is not easily figured out until we get a test Chartbook to duplicate the problem.
| [2014-09-24 13:55:17] |
| cmet - Posts: 742 |
Pretty basic. 6 tick PNF chart with Ask/Bid Volume Bars 1 minute chart with the overlay of Ask/Bid Volume Bars. CHT attached Date Time Of Last Edit: 2014-09-24 13:55:30
