Date/Time: Mon, 21 Apr 2025 04:38:27 +0000
Footprint data
View Count: 83
[2025-03-04 15:29:05]
User977892 - Posts: 8
Hi, after i opened my chart i noticed that there is some problem about my footprint. After the 24/02/2025 all my delta seems to be 0. Even the volume near the candlesticks show 0. Imagine: https://www.sierrachart.com/image.php?Image=174110144489.png
i have a second request. I wanted to set volume (near the candlestick) above 2250 like the purple color, and the volume above 3000 like the orange color. but it doesn't seem to function since smaller volume have the color that i wanted to put on the bigger one. Imagine: https://www.sierrachart.com/image.php?Image=1741101905306.png
[2025-03-04 16:30:31]
Sierra_Chart Engineering - Posts: 19285
You are now using Interactive Brokers data. Activate the exchange that you need here:
After that wait a few minutes and re-download the data:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location.
Regarding Numbers Bars coloring, You need to check all of the Compare Thresholds and color settings to make sure they are is intended:
Numbers Bars: Input Settings for Numbers Bars
Date Time Of Last Edit: 2025-03-04 16:32:48
