Date/Time: Mon, 21 Apr 2025 04:41:25 +0000
no data
View Count: 81
[2025-03-04 11:50:36]
User956873 - Posts: 23
ive had no reply to my last message can you help thanks
imageScreenshot 2025-03-03 184227.png / V - Attached On 2025-03-04 11:49:33 UTC - Size: 1.18 MB - 22 views
[2025-03-04 16:26:24]
Sierra_Chart Engineering - Posts: 19285
Restart Sierra Chart.
Set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes. If you have changed this setting, then reconnect to the data feed after by selecting 'File >> Reconnect".
