Date/Time: Mon, 21 Apr 2025 04:47:11 +0000
Large Volume Trade Indicator - text background
View Count: 229
[2025-03-04 10:38:49]
3698963 - Posts: 7
Hi team,
I am trying to change the background of the text in the large volume trade indicato. but unfortunately I cant find the option to modify from the current "white" to another color. (please see the attachment). could you please advice? thanks a lot
Best regards
imageLVI_textBackgroung.png / V - Attached On 2025-03-04 10:38:15 UTC - Size: 22.26 KB - 57 views
[2025-03-04 16:56:35]
John - SC Support - Posts: 39362
What is your "Draw Volume Text" set to?
[2025-03-07 10:16:23]
3698963 - Posts: 7
Hi John,
it is set "with background". please see the attachment.
thanks
imageLGI.png / V - Attached On 2025-03-07 10:16:02 UTC - Size: 74.98 KB - 29 views
[2025-03-07 15:34:17]
You cannot change the color of the background when displaying the numbers with the "Draw Volume Text" set to "with background".
The only way to have a different background would be to display the markers and set the "Draw Volume Text" to "Transparent". Then you can control the marker color with the "Bid/Ask Dominant Color Range Minimum/Maximum" Inputs.
[2025-03-09 11:10:42]
3698963 - Posts: 7
ok Thanks John,
the fact is that I saw that some friends have the backgroung which is black, without using the setting as you indicated.
we tried to understand why they have it black and I have itwhite but we did not find the reason yet.
if you have any update please let me know.
thank you
Luigi
[2025-03-10 15:45:56]
We are not sure. That is why we asked what your "Draw Volume Text" was set to, as you should have a black square background in that case. We do not see any way to have it otherwise, except to have the Draw Volume Text set to "Transparent".
