Date/Time: Fri, 18 Apr 2025 06:40:12 +0000
Charts not updating
View Count: 144
[2025-03-04 01:54:56] |
User618639 - Posts: 6 |
This morning when I logged on Sierra, the charts only loaded up to Sunday night at 19:44 EST. I checked to ensure that the data feed was connected, which it stated that it was. I'm not sure what has happened, or what else I need to check or do to be able to have my charts back updated. Thanks in advance!!! |
[2025-03-04 03:09:22] |
Sierra_Chart Engineering - Posts: 19259 |
Activate the CME exchange that you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-25 11:45:02] |
Jayshwinshah - Posts: 4 |
my charts are not updating even the historical data is not filling the dat on the charts correctly.
[2025-03-25 14:01:34] |
John - SC Support - Posts: 39353 |
Jayshwinshah: Please get us your Message Log by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
