Date/Time: Mon, 21 Apr 2025 04:41:23 +0000
MAKE TRADE WINDOW LARGER
View Count: 148
[2025-03-03 21:16:08] |
samlok43 - Posts: 5 |
Hello, can we make the trade window longer or wider? I am working with various OCOs and it is tough to go back and forth, thanks
[2025-03-04 15:46:25] |
John - SC Support - Posts: 39362 |
This is not possible at this time. We are working on a whole new format for the trade window which will not have any problems like this. It is through the Control Bar: Control Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-04 21:41:32] |
JohnR - User831573 - Posts: 330 |
As an old guy, I can use a larger font and window size. I presume it will be controllable via user Global setup. JohnR |
