Date/Time: Mon, 21 Apr 2025 04:41:26 +0000
DAILY TPO NOT LINING UP WITH ACTUAL PRICE ACTION
View Count: 152
[2025-03-03 20:31:04]
William Cline - Posts: 21
tpo range is different from the actual range and seems to extend farther for some reason. have the session time for the candles set to display price action from 00;00;00 to 23;59;59 but still the tpo candle is showing price action that did not happen within the time period of 1-20-2025. it appears the daily candles are misaligned and including price action from the previous day for some reason.
https://www.sierrachart.com/image.php?Image=1741033296445.png
https://www.sierrachart.com/image.php?Image=174103342042.png
https://www.sierrachart.com/image.php?Image=1741033594562.png
[2025-03-04 15:41:53]
John - SC Support - Posts: 39362
In one of the images you supplied, let us know what exactly you are seeing that does not look correct.
The reason we ask this is that we are not certain where the issue is, and you also have an inconsistency in that you state that the candles set to display price from 00:00:00 to 23:59:59, which we assume are the session times, but we can see that you have an evening session set to start at 16:15:00 in some of your images.
[2025-03-04 19:27:03]
As you can see on the chart showing 5 minute data of the 20th the entire price range only reaches the green lines but on the tpo daily candle it reaches the red lines. I don’t want this to happen because they are supposed to represent the same length of time. Which should be. 1-20-2025 00:00:00 to 23:59:59.I tried to turn off pm session so that the candle would just represent a clean 24 hours from 12am to 12pm but I can’t seem to make that happen on the daily tpo for some reason. I would appreciate some guidance on how to set up my daily top candle this way. From 12am to 12pm
[2025-03-04 22:03:34]
In order for the charts to show the same information, the Session Times MUST be set the same. Therefore, if you want to view data from 00:00:00 to 23:59:59, then you need to set your Session Times to those hours. In this case, you would not use the Evening Session times.
[2025-03-04 22:43:53]
i have noticed for some reason that my charts are not moving at all and for some reason are stuck at 17;00 for todays price data.
https://www.sierrachart.com/image.php?Image=1741128066250.png
[2025-03-04 23:26:03]
User584084 - Posts: 283
Futures do not trade between 17:00 PM EST and 17:59:59 PM EST Monday through Thursday. There is a 60 minute trading break. Futures trading resumes at 18:00 PM EST.
Date Time Of Last Edit: 2025-03-04 23:26:44
[2025-03-05 06:27:28]
Thank you for that user584084. I’ve also noticed that for some days in the snp500 it skips from 12:30 to 18:00. I’m not sure why
[2025-03-05 14:42:03]
If you are missing data in your chart, then refer to the following:
