Date/Time: Mon, 21 Apr 2025 04:38:26 +0000
Ray
View Count: 64
[2025-03-03 19:39:31] |
User266447 - Posts: 270 |
Can a label be added to a trend line (ray) to show the price level at which the line is located? If, yes - how can I do it? Thank you in advance.
[2025-03-04 15:10:44] |
John - SC Support - Posts: 39362 |
The Horizontal Ray tool has an option for "Show End Point Price". Refer to the following: Chart Drawing Tools: Horizontal Ray Configuration If you are using a different tool, then we would need to know which one exactly. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
