Date/Time: Mon, 21 Apr 2025 13:08:36 +0000
trade activity log fills not auto refreshing
View Count: 106
[2025-03-03 19:26:44] |
User114488 - Posts: 9 |
Been looking around for a while, sure I'm missing something easy. My fills are not auto populating in my TAL; must manually refresh. Appreciate help.
Date Time Of Last Edit: 2025-03-03 19:45:00
[2025-03-03 19:50:45] |
Sierra_Chart Engineering - Posts: 19285 |
We want you to update Sierra Chart to the current version. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-03 19:50:46] |
We want you to update Sierra Chart to the current version. Instructions: Software Download: Fast Update This should resolve the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-03 19:50:56
