Date/Time: Mon, 21 Apr 2025 13:11:42 +0000
Saving chart`s drawing - chartbook
View Count: 70
[2025-03-03 18:07:34]
User266447 - Posts: 270
If I draw a lot on the chart, such as trend lines, mark openings and closings, and write on the chart, and then save the changes (save all) after finishing my work, will I have all the annotations and trend lines saved in the chartbook if I copy this chartbook and open it on another computer in the SC software?
If not, what needs to be done to ensure that everything I have drawn and written on the chart is saved and can be transferred to another computer? For example, if I work on SC at my workplace and later want to transfer what I did there to my home computer.
Thanks in advance for your help!
[2025-03-03 18:23:37]
John - SC Support - Posts: 39362
Yes, drawings are stored with the chartbook.
