Date/Time: Mon, 21 Apr 2025 13:08:33 +0000
Placing a limit order on the keyboard
View Count: 93
[2025-03-03 09:38:36] |
User195394 - Posts: 5 |
Hello. I would like to know if it is possible. For example, I want to place a limit order to buy 7 ticks below the market just by configuring a key on the keyboard to be able to place the order without having to click on the price in the DOM and while keeping the use attached order? Is it possible? In the meantime, I thank you for all your support. Kind regards. |
[2025-03-03 10:27:46] |
Tr00pz - Posts: 20 |
Global Settings > Customize Keyboard Shortcuts. Expand 'Custom Trading Keyboard Shortcuts' and highlight 'Custom Trading Keyboard Shortcut 1' and click 'Customize Trading Command'. This will open a window that lets you choose Trade Type, Order Type, Reference Price, and Offset From Reference Price. You can set it up however you want then set the keyboard shortcut you want to use. You can also add these Custom Trading Keyboard Shortcuts to a control bar if you want. Experiment in simulation mode to get the custom setup correctly. As long as 'Use Attached Orders' is checked on the trade window for that chart, the orders will use the trade configuration you have selected.
Date Time Of Last Edit: 2025-03-03 10:28:34
