Date/Time: Mon, 21 Apr 2025 13:05:42 +0000
Draw vertical line across all regions on alert condition
View Count: 82
[2025-03-03 00:42:22] |
User180397 - Posts: 16 |
The drawing tool "Vertical Line" produces a line across all chart regions. Is it possible for SC to draw a similar vertical line across all regions triggered by an alert condition? (I think I have read all Color Bar and Color Background info, but a solution still eludes me. If this is not possible, I will suggest that for future development consideration. IMHO, the study "Time Line" would also benefit from an optional ability to be drawn across all regions at once. Second question: Is there a library or forum where all the SC studies are described in layman terms? I am frustrated at times looking at the vast SC library of study titles, without the ability to conceptualize the math formulas which are at times offered as the only explanation or description. Regards, Bob M |
[2025-03-03 07:03:35] |
Sierra_Chart Engineering - Posts: 19285 |
There is no study which is capable of drawing a vertical line across all chart regions. We would have to add a new draw style for that. We will see about that. Regarding studies there is nothing more than the information here: Technical Studies Reference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
