Date/Time: Mon, 21 Apr 2025 04:41:22 +0000
[Programming Help] - ACSIL Semi Automation
View Count: 111
[2025-03-02 23:17:02] |
Gradient - Posts: 121 |
Hi, What is the best way to combine the execution and trade management from a ACSIL automated system with the ability to execute manually? Risk and trade management is all handled inside of automated system, but only once user enters position. Thanks |
[2025-03-02 23:36:42] |
cmet - Posts: 690 |
Need to know more about what your "risk and trade management" rules are. If it's just stops and targets, why would you need an automated system? You could just use attached orders. |
[2025-03-04 06:23:03] |
Sierra_Chart Engineering - Posts: 19285 |
You would just simply manually enter a position, and the custom study would see the existence of the position and do what it needs in regards to submitting orders to close the position. So the first step is to check for the existence of the position: Automated Trading From an Advanced Custom Study: sc.GetTradePosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-04 07:06:59] |
Makes sense. Thanks
