Date/Time: Mon, 21 Apr 2025 04:47:16 +0000
Label on intersected VPOC
View Count: 131
[2025-03-02 13:29:40] |
gz6969 - Posts: 30 |
Hi, when I draw volume profiles manually the label for an already intersected VPOC will be displayed on the y axis. Interestingly no label will be displayed for peaks and valleys if they are intersected. If you look at my chart I've marked the labels which are ok or not(from my point of view). Is it possible to suppress labels for intersected POCs as you do it for peaks and valleys? https://www.sierrachart.com/image.php?Image=1740921240746.png When I use periodic daily or weekly profiles the label for intersected POCs is not displayed on the y axis! https://www.sierrachart.com/image.php?Image=1740921917367.png Future Intersection Method is set to chart bars on all profiles. |
[2025-03-03 15:48:39] |
John - SC Support - Posts: 39362 |
We are not able to reproduce what you are seeing. Please get us a chart that shows this so we can take a look. Follow these instructions to get us the chart: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-03 21:36:56] |
Please see the attached chartbook. The labels of the MCVPOCs at 6068.00 and 5863.75 are not ok because they are already intersected. This is how the chart looked at the time I've saved and uploaded the chartbook. https://www.sierrachart.com/image.php?Image=1741037732816.png |
[2025-03-04 15:59:49] |
The reason for what you are seeing is that when you set the Input for "Draw Mode" to be "Volume Profiles & POC, VAH, VAL, VWAP Lines" you will get the Name and Value Label showing, even if the line has been intersected. Since you are extending the lines, you can set the "Draw Mode" to be "Volume Profile" and still have the extension line showing.
[2025-03-04 20:21:12] |
Hey great! Thanks a lot John
