Date/Time: Mon, 21 Apr 2025 13:08:33 +0000
all formula's removed in scss spreadsheet file
View Count: 88
[2025-03-02 10:13:28] |
sabbers - Posts: 27 |
I use Spreadsheet system for trading and have an issue upon opening Sierra Chart Somehow the spreadsheet window was attached. Before is was detached. All data added in formula colomns are now empty. Also all formula's have disappeard. Basically the spreadsheet is empty, apart from the default info and study info. I have the correct .scss file and also the correct sheet number. Also i noticed that all sheets in the spreadsheet are empty apart from the default info. I must say in the prior session i changed the number of formula columns from 16 to 30. But after that all formula's were stil present. I closed Sierra Chart normally and saved all. What could have happened? Regards! Date Time Of Last Edit: 2025-03-02 10:14:38
[2025-03-03 07:01:02] |
Sierra_Chart Engineering - Posts: 19285 |
Go to a backup spreadsheet file: Working with Spreadsheets: Accessing a Backup Spreadsheet File And one reason this can occur is based upon how the Formula Source Sheet Number Input is set: Spreadsheet Study Inputs: Formula Source Sheet Number Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
