Date/Time: Mon, 21 Apr 2025 13:11:43 +0000
Separate order entries with no average line
View Count: 84
[2025-03-02 03:36:24] |
cjb111 - Posts: 18 |
Hello Support Is their a way to keep your entries from averaging. For example. Say I took a buy at $2 and another at $5. can I keep them separate and not have the entry line move to $3.5 Thank you Jermain |
[2025-03-03 15:35:36] |
John - SC Support - Posts: 39362 |
Sierra Chart only has the one Average Position line. There is no support for separate position lines.
