Date/Time: Mon, 21 Apr 2025 13:11:35 +0000
Why my chart is blank?
View Count: 129
[2025-03-01 15:49:12]
Incerto - Posts: 2
Following the instruction of use free trial, i open: symbol-binance-BTCUSDT-historical chart, but the chart is totally blank
As described above I also upload my screenshot, thx for help
imageSnipaste_2025-03-01_23-48-06.png / V - Attached On 2025-03-01 15:48:18 UTC - Size: 40.97 KB - 30 views
[2025-03-01 18:19:03]
ForgivingComputers.com - Posts: 1042
Whenever a blank chart appears, the first thing to try is this:
Edit>>Translate Symbols To Current Service
If that doesn't work, then you might want to post your Windows Message Log.
[2025-03-02 23:22:56]
Sierra_Chart Engineering - Posts: 19285
We see you are on a trial. Make sure you are using the supported symbols during a trial:
Sierra Chart Trial Account
Use this symbol instead:
BTCUSD_PERP_BINANCE
[2025-03-03 00:33:27]
Restart Sierra Chart. You should be able to access this particular symbol now.
Date Time Of Last Edit: 2025-03-03 00:33:36
