Date/Time: Mon, 21 Apr 2025 13:11:41 +0000
[User Discussion] - Number Bars calculated values
View Count: 122
[2025-03-01 09:35:07]
Gdraw1234 - Posts: 3
Hi, i want to show the range of the "body" of each candle(Close - Open) in the study: Number Bars calculated values. Thanks
The closest thing i can find is High-Low range(SG41) in subgraphs of Number Bars calculated values, but it not exactly the same thing.
[2025-03-01 14:20:17]
Sawtooth - Posts: 4209
The Numbers Bars Calculated Values study does not output the candle body range in any of its subgraphs.
To calculate that value, use the Spreadsheet Formula study with this formula in its Formula field:
=ABS(C-O)
If you want that range in ticks, use this formula:
=ABS(C-O)/TICKSIZE
Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#ABS_Function
[2025-03-02 10:21:06]
Thank you very much, it work
Date Time Of Last Edit: 2025-03-02 10:38:27
