Date/Time: Mon, 21 Apr 2025 13:17:35 +0000
Volatility symbols for other stocks
View Count: 101
[2025-03-01 04:50:41]
User173763 - Posts: 7
Hey Support,
On the CBOE Global Index there are volatility symbols for some companies like VXIBM. Can't find similar though for others like MSFT or NVDA. Maybe somewhere else ? Maybe there is subscription package i need to activate ?
Thanks you in advance
[2025-03-03 15:07:12]
John - SC Support - Posts: 39362
It looks like there is the following available in terms of VIX for equities:
- VXAPL - VXAPL (Cboe APPLE VIX)
- VXAZN - Cboe Options on AMZN - Amazon Inc.
- VXGOG - Cboe Equity VIX on Google
- VXGS - Cboe Equity VIX on Goldman Sachs
- VXIBM - Cboe Equity VIX on IBM
You would need to check with the CBOE on why these are the only ones they have available. We do not have another feed that has everything you are looking for (and it looks like it probably doesn't exist).
You can view the items available from the CBOE Global Indices at the following link in the section for "CBOE Global Indices":
https://www.cboe.com/us/indices/indicesproducts/#cgi
