Date/Time: Mon, 21 Apr 2025 13:11:42 +0000
How to remove the Bid-Ask Lines as seen in the image attached
View Count: 191
[2025-03-01 02:17:11] |
User501309 - Posts: 15 |
In 'Replay mode' I see the green/red bid-ask lines on some charts. I do not have 'Chart>Show Bid and Ask Lines' selected and I do not have the Study 'Bid & Ask Prices' running. I am seeing these lines on a few charts at this time. I only want to see the study 'Current Price Line' which you can see is running (yellow line). How do I remove the Bid-Ask Lines? https://www.sierrachart.com/image.php?Image=174079455220.png |
[2025-03-01 20:17:11] |
blt - Posts: 59 |
...go to "Studies" ...find in list "Current Bid Ask Lines" ...click on "Remove" or check out "Hide" |
[2025-03-01 22:29:47] |
blt > Not running that study
[2025-03-01 22:40:38] |
blt - Posts: 59 |
...sorry ...just saw it "Replay mode" |
[2025-03-02 14:12:42] |
User925540 - Posts: 62 |
>> Trade >> Draw DOM Graph On Chart
[2025-03-03 00:28:52] |
Sierra_Chart Engineering - Posts: 19285 |
Make sure this is disabled: Trade Menu: Draw DOM Graph on Chart (Trade menu) Next, Hide each study one by one and see if this is drawn by a study. Refer to: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-03-03 00:29:09
