Date/Time: Mon, 21 Apr 2025 13:14:32 +0000
Unable to enter using stop order NQ micro
View Count: 121
[2025-02-28 22:25:29] |
User696540 - Posts: 29 |
Hello, I have both my own account with AMP and also have an Apex account. I'm able to enter on a Stop order with Apex but on my live account....trading NQ micros... the resting order shows as Stop Limit and not just "Stop" FYI I'm using teton CME routing on the AMO account. However, in SIM it does show as a Buy Stop like in the Apex account. Attaching the Chart DOM settings Thanks |
[2025-02-28 22:31:02] |
John - SC Support - Posts: 39362 |
Refer to the following: Order Types: Stop Orders on the CME For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-28 22:43:00] |
User195657 - Posts: 6 |
Thanks for your super quick reply. However, I'm placing the order in EXACTLY the same way on the AMP account as on the Apex account. But on the AMP live account, the order is getting entered as a Stop Limit and not a stop order. But it IS entered correctly as a Stop order when trading from the Apex account |
[2025-03-03 14:50:38] |
That is something you would need to take up with APEX.
[2025-03-03 15:15:49] |
The Apex account with Rithmic is actually the one that is working correctly It's the AMP account with Teton that's not doing ANY stop orders. Even the trades where I'm using a Stop Loss via a Stop order are showing as Stop Limit order when I'm stopped out. |
[2025-03-03 17:26:08] |
The CME Group converts ALL Stop orders to "Stop Limit".
