Date/Time: Fri, 20 Sep 2024 05:38:54 +0000
To delete unwanted anchored drawing
View Count: 925
[2014-09-23 03:50:35] |
yalefx - Posts: 7 |
I have copied chart from other SC user, which contains in lower pane RSI with anchored extended rectangle drawing highlighting range 40 to 60. I have deleted this study and replaced it with cumulative delta volume study with intention to start at 0 at start of each RTH session. I accomplished that, but I do not know, how to delete anchored drawings of previous user, now "messing" Cum Delta picture( for detail parametres of RSI range drawing and example of CumDelta, see attached screen shots). Thank you in advance for your help. |
Anchored RSI range illustration.xlsx - Attached On 2014-09-23 03:49:41 UTC - Size: 11.17 MB - 386 views Attachment Deleted. |
[2014-09-23 09:26:51] |
To post an image of the chart, use this method here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image We will not accept an XLSX file. However, you can find the chart drawing through Tools >> Manage Chart Drawings Window. Locate the drawing in the list and press the Delete button at the bottom of the window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-23 09:27:18
