Date/Time: Mon, 21 Apr 2025 13:14:36 +0000
workaround for Color TPO Row based on % POC Volume not overriding other input settings
View Count: 101
[2025-02-28 21:39:38]
cipher - Posts: 1
i currently have TPO charts setting "Color TPO Row Based on Percentage of POC Volume" enabled, but want to display the open and close of each new sub period.
in the docs it specifically states it "takes precedence over the other input settings such as Highlight Midpoint in Profile, Highlight Open Of Each New Sub Period Within TPO Profile, Highlight TPO Value Area, Highlight Close in Profile, Highlight Close of Each New Sub Period Within TPO Profile and TPO Letter/Block Colors.", so i understand why it is currently not showing with the Color TPO row option on.
are we able to change the "other input settings" to take precedence over Color TPO row?
my reasoning is, if the other input settings take precedence, and the user has Color TPO row on, and does NOT want each of the other input settings to show up, they can just easily disable each input setting they don't want to see.
if this isn't possible, is there any workaround with this option on, while displaying the open and close of each new sub period? im looking for a workaround without setting "Color Letters For Value Area And Point Of Control Instead Of Background" to No (prefer letters to be colored).
for example, with Color TPO row option on, im able to get the midpoint of each sub period to display, but i think its only because its drawing a border around the letter (rather than coloring).
the open and close of the sub periods are the only thing im missing for my TPO charts, otherwise everything else is perfect!
[2025-02-28 22:21:02]
John - SC Support - Posts: 39362
We cannot say whether this would be something that could be done or not. But it is not something we have time to look into at the moment. We have set this as a "Feature Request", so it is on our list of things to look into, but we cannot say when we would get to this, or to any particular feature request.
