Date/Time: Mon, 21 Apr 2025 13:11:40 +0000
forex
View Count: 95
[2025-02-28 18:28:11]
SafSaf - Posts: 126
alright lads, i'm looking to start forex trading and i'm just wondering how to set the price per pip. i'e been trading futures only up to now.
[2025-02-28 21:42:23]
John - SC Support - Posts: 39362
FOREX does not use the "Currency Value per Tick". It is just the difference in price divided by the quantity.
[2025-02-28 22:00:48]
SafSaf - Posts: 126
comming from futures trading i am a little confused with your reply, probably my ignorance, i have an ibkr accoun i can connect to trade forex however i need more detailed information in laymans terms of how to set up to trade forex. i notice on mt5 platform that one can chose how much they want to apply to a tick?
[2025-02-28 22:29:46]
Say you buy long at a price of 1.0585 and sell at a price of 1.0600 for a lot size of 10000. Your profit is (1.0600 - 1.0585) * 10000 = 15.00.
[2025-03-01 11:40:04]
SafSaf - Posts: 126
ok, to avoid confusion on my part, when I choose my currency pair in chart settings, do I need to change any futher settings in the attached, or are they automatically set for the selected symbol?
imageScreenshot 2025-03-01 at 11.37.40.png / V - Attached On 2025-03-01 11:38:36 UTC - Size: 49.74 KB - 19 views
[2025-03-01 18:32:49]
ForgivingComputers.com - Posts: 1042
FYI: In FOREX the Tick Size is the same as the pip size. It is automatically set when you change symbols.
