Date/Time: Mon, 21 Apr 2025 13:11:36 +0000
Order ID
View Count: 92
[2025-02-28 17:38:18] |
User871314 - Posts: 7 |
Hi, Is there a way to track CME order ID for each order on ES? They explain on their MDP but essentially it's a unique order ID to provide customer anonymity. If it can't be tracked directly within Sierra as is, can this information be fed in from an external source? Thanks. |
[2025-03-03 08:22:03] |
Sierra_Chart Engineering - Posts: 19285 |
This is accessible through ACSIL: ACSIL Interface Members - Functions: sc.GetAskMarketLimitOrdersForPrice() ACSIL Interface Members - Functions: sc.GetBidMarketLimitOrdersForPrice() But only for orders with a quantity greater than 3 or higher. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
