Date/Time: Mon, 21 Apr 2025 13:05:44 +0000
Better rithmic connection data feed
View Count: 143
[2025-02-28 09:00:18]
CharlieCee - Posts: 5
Hi, i would like to know how to get a better rithmic connection.
I heard with Denali data feed and teton order routine it will be good ( i have to open an future account for non.professionnel trader of course )
Can you help me and explain the.process ?
[2025-02-28 15:08:49]
John - SC Support - Posts: 39362
Are you trading with a Prop Firm or are you trading your own funds in your own personal account?
[2025-02-28 15:55:58]
With bulenox prop firm
[2025-02-28 16:38:05]
With Bulenox, you can not get around using Rithmic for the order routing. That is what they use.
You can get the data from our Denali Exchange Data Feed, however, but in order to get the data at the non-professional rates, you need to have a live, funded, futures trading account and you need to connect your Sierra Chart to that account at least once a month for verification. Refer to the following:
Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Once you have the above worked out (i.e. you have an account that meets the requirement or you will pay for the Professional data) then you can setup the data for the CME Group by following these instructions:
