Date/Time: Mon, 21 Apr 2025 13:11:37 +0000
DOM tpo lines study
View Count: 106
[2025-02-28 01:43:47] |
User581066 - Posts: 31 |
Hi, So i use the TPO Line study with my dom. The study is set in minutes, for a period of 30min. So until yesterday the study was showing 2 different levels for VAH, POC and VAL. As you can see in the picture attached the study was showing 2 VAL levels (in the Green circles ) . At the end of the period the previous level would stay in the chart while the level for the New period would form. My issue is that I opened a new dom and when I used the study, now the study only display one level at once and when a new period start it doesnt keep the level for the previous period on chart. How can I see the level for the previous period AND the level for the current period on my DOM usine the TPO lines study ? Thanks you all for everything. Date Time Of Last Edit: 2025-02-28 01:44:57
Private File |
[2025-02-28 15:00:31] |
John - SC Support - Posts: 39362 |
One of two things occurred in the situation where the previous session lines were still visible: - The system had not performed a full recalculation removing the old lines. - You were looking at the Trading DOM at the time of the transition from the old session to the new one. We do not know which applies in this case, although it is most likely the latter. In either case, it was just a happenstance that caused it to occur. The easiest way to get both sets of lines showing is to use two copies of the "TPO Value Area Lines" in which one is setup to reference 1 period back ("Reference n Periods Back" Input). Refer to the following: TPO Value Area Lines: Inputs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
