Date/Time: Tue, 14 Jul 2026 06:00:33 +0000
Prop firm connection
View Count: 2016
[2025-02-27 23:24:47]
lovelivelaught - Posts: 94
Hello
I just signed up for Bulenox and I have to get Rithmic connection to use the account.
I currently have a live Rithmic connection through my broker Discount trading and would like to keep using it as well. Bulenox told me that i will not be able to use both Rithmic connections( Bulenox and with Discount trading) simultaneously and that i should reach you out for a possible solutions? I have 5 instances of Sierra charts and Also I have second installation of Sierra chart. What can be done?
[2025-02-28 06:29:50]
Sierra_Chart Engineering - Posts: 24257
The information you received is wrong. You can use both of those Rithmic accounts at the same time because they are two different servers or different usernames.
[2025-02-28 12:09:16]
Ok that is a nice surprise. So how can I use it? Sign in with one of my subinstances with new Rithmic from Bulenox. I have my current Rithmic on main Sierra chart. My data/trade service settings look different on main and on all subinstances of Sierra chart. It does not look like that i can sign in sub-instances same way as i can in my main Sierra chart?
[2025-02-28 15:54:48]
John - SC Support - Posts: 47164
You need to install another installation of Sierra Chart:
Using Multiple Data and Trading Services at the Same Time
But the Denali Exchange Data Feed is going to limit you to three simultaneous connections on the same computer. Refer to the following:
Denali Exchange Data Feed: Denali Exchange Data Feed Connections on Same Computer Simultaneously
[2025-02-28 17:29:22]
I already have a separate installation of Sierra and tried to log in with my Bulenox loggin but I got an error connecting to Data or trading services. Please help me with what I am doing wrong.
Bulenox wants me to pick a Rithmic paper trading. But I am not sure about Current Selected Service?
Screenshot attached.
imageScreenshot 2025-02-28 232717.png / V - Attached On 2025-02-28 17:27:49 UTC - Size: 29.99 KB - 164 views
[2025-02-28 21:37:16]
That is the correct "Current Selected Service" as that is the only option for Rithmic.
What is the error you are getting?
[2025-03-01 00:07:53]
Here it is
2025-02-28 10:10:24.998 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-02-28 10:10:24.998 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-02-28 10:10:24.998 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-02-28 10:10:24.999 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-02-28 10:10:24.999 | DTC Client socket (2) | New receive buffer size: 0
2025-02-28 10:10:24.999 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-02-28 10:10:25.298 | Rithmic Direct - DTC | Network connection to server complete.
2025-02-28 10:10:25.298 | Rithmic Direct - DTC | Starting socket receive thread.
2025-02-28 10:10:25.298 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-02-28 10:10:25.298 | Rithmic Direct - DTC | Sending logon request message.
2025-02-28 10:10:29.960 | Rithmic Direct - DTC | Received logon response.
2025-02-28 10:10:29.960 | Rithmic Direct - DTC | Server Name: .
2025-02-28 10:10:29.960 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-02-28 10:10:29.960 | Rithmic Direct - DTC | Logon error received from server: permission denied
2025-02-28 10:10:29.960 | Rithmic Direct - DTC | Failed connections: 49
2025-02-28 10:10:29.960 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-02-28 10:10:29.960 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-28 10:10:29.983 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-02-28 10:10:29.983 | DTC Client socket (2) | CloseSocket call.
2025-02-28 10:10:29.983 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-02-28 10:10:29.983 | Rithmic Direct - DTC | Disconnected.
2025-02-28 10:10:29.983 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2025-02-28 10:10:31.137 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-02-28 10:10:31.137 | DTC Client socket (2) | Closed.
2025-02-28 10:10:45.240 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2.
2025-02-28 10:10:45.240 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | New receive buffer size: 0
2025-02-28 10:10:45.240 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Connecting to IP: 216.66.0.130.
2025-02-28 10:10:46.166 | Rithmic Direct - DTC | Wrote file: D:\SierraChart2\RithmicConnections.json. Size: 81131
2025-02-28 10:10:46.166 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-02-28 10:10:46.417 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | CloseSocket call.
2025-02-28 10:10:46.417 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close.
2025-02-28 10:10:46.570 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Socket gracefully closed by remote side.
2025-02-28 10:10:46.570 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (2) | Closed.
2025-02-28 10:12:02.518 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-28 10:12:02.518 | DTC Client socket (1) | Closed.
[2025-03-02 18:14:13]
User135243 - Posts: 282
you've to use the Bulenox Server and not the Rithmic PaperTrading Server
[2025-03-03 15:51:59]
You are getting the following error in your log:
Most likely it is what User135243 states and you need to select the correct server.
But just in case, the information we have on the "Permission Denied" error can be found here:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
[2025-03-03 17:47:29]
All is working now but when I was connected to Rithmic paper trading it was actually the right connection.
I assume that I would have to connect to Bulenox after my test on parer trading completed and then I move to live Bulenox account.
Thank you
[2025-03-03 23:07:16]
I get only a week of historical data with this new connection. I contacted Bulenox but they send me a link to Sierra chart.
I have set Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds.
How can I get historical data?
[2025-03-03 23:52:51]
To my previous post about historical data. Never mind i figured it out. I got it. Thanks
[2025-03-04 21:27:11]
I am trying to improve performance of my second installation of Sierra but I got an error; "Error bundling to UDP port 22904. Windows error code 10048. Only one usage of each socket address (protocol/network address) is normally permitted."
I guess I can not use a sub instance? What would you advice? The platform is noticeably slow. I went through all Sierra help topics to try to improve the performance but no luck.
I also use another installation of Sierra with 4 sub instances where I use same chart set ups but separated in 4 different instances which noticeably helped to improve performance. But I assume that I can not use Bulenox connection with few instances?
[2025-03-04 22:18:32]
You can, but you need to be careful and setup the DTC Protocol to use different ports so that each installation's sub-instances are connecting properly. Refer to the following:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Resolving DTC Protocol Server Port Number Conflicts
[2025-03-05 00:59:05]
Set the UDP port to 0. You do not need it:
Sierra Chart Server Settings: UDP Port (Global Settings >> Sierra Chart Server Settings >> General >> General)
[2025-03-05 17:45:16]
Everything was working fine this morning but then charts got frozen though there was a connection available ( price on scale was moving but not charts).
Not sure what happened but i cleared a Data file this morning to improve platform performance as there was bunch of data stored from 2021, which helped a bit with performance of the platform.
But now I do not have any symbols available in any of symbol windows. It is empty, The charts that was opened with symbol are in a mode "Waiting to download historical data" already for a while
2025-03-05 10:22:41.882 | Trade activity files set size: 1423
2025-03-05 10:22:41.923 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-03-05 10:22:41.962 | Created the DTC Protocol server.
2025-03-05 10:22:41.967 | DTC Protocol Server listening on port 11115.
2025-03-05 10:22:41.967 | Reading Internal Order ID file.
2025-03-05 10:22:41.982 | Reading Trade Orders file.
2025-03-05 10:22:41.982 | Reading Trade Positions file.
2025-03-05 10:22:41.982 | Reading Trade Account Data files.
2025-03-05 10:22:42.027 | Software version: 2743 64-bit
2025-03-05 10:22:42.027 | Primary Thread ID: 2864
2025-03-05 10:22:42.027 | Usage end date: 2025-03-21
2025-03-05 10:22:42.027 | Enabled for: Advanced Features 2.
2025-03-05 10:22:42.027 | Enabled for: Sierra Chart Historical Data Service.
2025-03-05 10:22:42.027 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-03-05 10:22:42.027 | Enabled for: Delayed Denali Exchange Data Feed.
2025-03-05 10:22:42.027 | Enabled for exchange2: CME
2025-03-05 10:22:42.027 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-03-05 10:22:42.027 | Current selected Data/Trading service: Rithmic Direct - DTC
2025-03-05 10:22:42.027 | Custom symbol settings values: disabled
2025-03-05 10:22:42.027 | Chart Update Interval: 1000
2025-03-05 10:22:42.027 | Intraday Data Storage Time Unit: 0
2025-03-05 10:22:42.027 | Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00)
2025-03-05 10:22:42.027 | 2025-03-05 17:22:42 Local computer time in UTC
2025-03-05 10:22:42.027 | 2025-03-05 10:22:42 Local computer time in SC Time Zone
2025-03-05 10:22:42.027 | 2025-03-05 17:22:41 Server time in UTC
2025-03-05 10:22:42.027 | Local computer UTC time and Server UTC time difference: 0 seconds.
2025-03-05 10:22:42.027 | Program path: D:\SierraChart2\
2025-03-05 10:22:42.027 | Data Files path: D:\SierraChart2\Data\
2025-03-05 10:22:42.027 | OS Version Number: 10.0
2025-03-05 10:22:42.027 | Locale Setting: C
2025-03-05 10:22:42.027 | DLLs: UserContributedStudies_64.dll
2025-03-05 10:22:42.027 | Allowed protected custom studies: zyp_download_free
2025-03-05 10:22:42.027 | Crash reporter started: true
2025-03-05 10:22:42.058 | Created the DTC Protocol historical data server.
2025-03-05 10:22:42.061 | HD Server Manager | Listening on port 11114.
2025-03-05 10:22:42.062 | Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic_v2.trading. Request ID: 1.
2025-03-05 10:22:42.116 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-03-05 10:22:42.148 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2.
2025-03-05 10:22:42.149 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | New receive buffer size: 0
2025-03-05 10:22:42.149 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Connecting to IP: 216.66.0.130.
2025-03-05 10:22:42.296 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-03-05 10:22:42.297 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-03-05 10:22:42.672 | Received 5 login tokens.
2025-03-05 10:22:43.080 | Rithmic Direct - DTC | Wrote file: D:\SierraChart2\RithmicConnections.json. Size: 81131
2025-03-05 10:22:43.081 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-03-05 10:22:43.188 | Symbol settings MD5 received. Request ID: 1.
2025-03-05 10:22:43.188 | Symbol settings are up-to-date for rithmic_v2.trading.
2025-03-05 10:22:43.325 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | CloseSocket call.
2025-03-05 10:22:43.325 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close.
2025-03-05 10:22:43.477 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Socket gracefully closed by remote side.
2025-03-05 10:22:43.477 | HTTPS connection ID:1 to downloads.rithmic.com:443 for request ID:1 (4) | Closed.
2025-03-05 10:22:44.561 | Requested user files to download.
2025-03-05 10:22:46.570 |
2025-03-05 10:22:46.570 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:22:46.570 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:22:46.573 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-03-05 10:22:46.573 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-03-05 10:22:46.573 | DTC Client socket (1) | New receive buffer size: 0
2025-03-05 10:22:46.573 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-03-05 10:22:46.822 | Rithmic Direct - DTC | Network connection to server complete.
2025-03-05 10:22:46.822 | Rithmic Direct - DTC | Starting socket receive thread.
2025-03-05 10:22:46.822 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-03-05 10:22:46.822 | Rithmic Direct - DTC | Sending logon request message.
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | Received logon response.
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | Server Name: .
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | Successfully connected.
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | Trading is supported.
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | OCO Orders supported.
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | Connected to server complete.
2025-03-05 10:22:47.538 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-03-05 10:22:47.538 | Using symbol data fast lookup vector
2025-03-05 10:22:47.538 | Rithmic Direct - DTC | Starting real-time market data updates for: BOIL. ID: 1
2025-03-05 10:22:47.541 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:22:47.541 | Rithmic Direct - DTC | Requesting security definition data for: BOIL. ID: 1
2025-03-05 10:22:47.541 | Starting DelayedDownloadMonitoringTimer
2025-03-05 10:22:47.541 | Starting HDTimeoutTimer
2025-03-05 10:22:47.541 | Added historical Intraday data request for BOIL to the queue.
2025-03-05 10:22:47.541 | Intraday data recording state for symbol BOIL is set to download 'Pending'.
2025-03-05 10:22:47.541 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:22:47.542 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:22:47.542 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:22:47.544 | Triggering next historical data download in queue.
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Starting real-time market data updates for: FAS. ID: 2
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Requesting security definition data for: FAS. ID: 2
2025-03-05 10:22:47.544 | Added historical Intraday data request for FAS to the queue.
2025-03-05 10:22:47.544 | Intraday data recording state for symbol FAS is set to download 'Pending'.
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Starting real-time market data updates for: GUSH. ID: 3
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Requesting security definition data for: GUSH. ID: 3
2025-03-05 10:22:47.544 | Added historical Intraday data request for GUSH to the queue.
2025-03-05 10:22:47.544 | Intraday data recording state for symbol GUSH is set to download 'Pending'.
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Starting real-time market data updates for: ICLN. ID: 4
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Requesting security definition data for: ICLN. ID: 4
2025-03-05 10:22:47.544 | Added historical Intraday data request for ICLN to the queue.
2025-03-05 10:22:47.544 | Intraday data recording state for symbol ICLN is set to download 'Pending'.
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Starting real-time market data updates for: LABU. ID: 5
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Requesting security definition data for: LABU. ID: 5
2025-03-05 10:22:47.544 | Added historical Intraday data request for LABU to the queue.
2025-03-05 10:22:47.544 | Intraday data recording state for symbol LABU is set to download 'Pending'.
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Starting real-time market data updates for: LIT. ID: 6
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Requesting security definition data for: LIT. ID: 6
2025-03-05 10:22:47.544 | Added historical Intraday data request for LIT to the queue.
2025-03-05 10:22:47.544 | Intraday data recording state for symbol LIT is set to download 'Pending'.
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Starting real-time market data updates for: NUGT. ID: 7
2025-03-05 10:22:47.544 | Rithmic Direct - DTC | Requesting security definition data for: NUGT. ID: 7
2025-03-05 10:22:47.544 | Added historical Intraday data request for NUGT to the queue.
2025-03-05 10:22:47.544 | Intraday data recording state for symbol NUGT is set to download 'Pending'.
2025-03-05 10:22:47.545 | Rithmic Direct - DTC | Starting real-time market data updates for: SOXL. ID: 8
2025-03-05 10:22:47.545 | Rithmic Direct - DTC | Requesting security definition data for: SOXL. ID: 8
2025-03-05 10:22:47.545 | Added historical Intraday data request for SOXL to the queue.
2025-03-05 10:22:47.545 | Intraday data recording state for symbol SOXL is set to download 'Pending'.
2025-03-05 10:22:47.545 | Rithmic Direct - DTC | Starting real-time market data updates for: SPXL. ID: 9
2025-03-05 10:22:47.545 | Rithmic Direct - DTC | Requesting security definition data for: SPXL. ID: 9
2025-03-05 10:22:47.545 | Added historical Intraday data request for SPXL to the queue.
2025-03-05 10:22:47.545 | Intraday data recording state for symbol SPXL is set to download 'Pending'.
2025-03-05 10:22:47.545 | Rithmic Direct - DTC | Starting real-time market data updates for: TECL. ID: 10
2025-03-05 10:22:47.545 | Rithmic Direct - DTC | Requesting security definition data for: TECL. ID: 10
2025-03-05 10:22:47.545 | Added historical Intraday data request for TECL to the queue.
2025-03-05 10:22:47.545 | Intraday data recording state for symbol TECL is set to download 'Pending'.
2025-03-05 10:22:47.545 | Rithmic Direct - DTC | Starting real-time market data updates for: TNA. ID: 11
2025-03-05 10:22:47.545 | Rithmic Direct - DTC | Requesting security definition data for: TNA. ID: 11
2025-03-05 10:22:47.545 | Added historical Intraday data request for TNA to the queue.
2025-03-05 10:22:47.545 | Intraday data recording state for symbol TNA is set to download 'Pending'.
2025-03-05 10:22:47.545 | Delaying start of download for BOIL.
2025-03-05 10:22:47.800 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:22:47.800 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:22:47.800 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:22:47.800 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:22:48.569 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:22:48.824 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:22:48.824 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:22:48.824 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:22:48.825 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:22:48.825 | DTC Client socket (2) | Closed.
2025-03-05 10:22:48.825 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:22:48.825 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:22:48.825 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:22:49.794 | Files to Open on Startup | Opening file: Crude+Gold.Cht
2025-03-05 10:22:49.830 | CLJ5.NYMEX [CV] 5 Min #2 | Reloading chart.
2025-03-05 10:22:49.830 | CLJ5.NYMEX [CV] 5 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:49.830 | CLJ5.NYMEX [CV] 5 Min #2 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:49.893 | Loading DLL: D:\SierraChart2\Data\UserContributedStudies.dll (UserContributedStudies_64.dll). Handle: 7ffbb12c0000
2025-03-05 10:22:49.914 | CLJ5.NYMEX [CV] 5 Sec #3 | Reloading chart.
2025-03-05 10:22:49.914 | CLJ5.NYMEX [CV] 5 Sec #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:49.914 | CLJ5.NYMEX [CV] 5 Sec #3 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:49.969 | CLJ5.NYMEX [CV] 2 Min #5 | Reloading chart.
2025-03-05 10:22:49.969 | CLJ5.NYMEX [CV] 2 Min #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:49.969 | CLJ5.NYMEX [CV] 2 Min #5 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:49.989 | CLJ5.NYMEX [CV] 1 Min #8 | Reloading chart.
2025-03-05 10:22:49.989 | CLJ5.NYMEX [CV] 1 Min #8 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:49.989 | CLJ5.NYMEX [CV] 1 Min #8 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:50.462 | GCJ5.COMEX [CV] #4 | Reloading chart.
2025-03-05 10:22:50.462 | GCJ5.COMEX [CV] #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:50.462 | GCJ5.COMEX [CV] #4 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:50.489 | CLJ5.NYMEX [CV] 1 Min #7 | Reloading chart.
2025-03-05 10:22:50.489 | CLJ5.NYMEX [CV] 1 Min #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:50.489 | CLJ5.NYMEX [CV] 1 Min #7 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:50.515 | GCJ5.COMEX [CV] 5 Min #1 | Reloading chart.
2025-03-05 10:22:50.515 | GCJ5.COMEX [CV] 5 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:50.515 | GCJ5.COMEX [CV] 5 Min #1 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:50.542 | GCJ5.COMEX [CV] 5 Sec #6 | Reloading chart.
2025-03-05 10:22:50.542 | GCJ5.COMEX [CV] 5 Sec #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:50.542 | GCJ5.COMEX [CV] 5 Sec #6 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:50.618 | GCJ5.COMEX [CV] 2 Min #9 | Reloading chart.
2025-03-05 10:22:50.618 | GCJ5.COMEX [CV] 2 Min #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:50.618 | GCJ5.COMEX [CV] 2 Min #9 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:50.640 | GCJ5.COMEX [CV] 1 Min #10 | Reloading chart.
2025-03-05 10:22:50.640 | GCJ5.COMEX [CV] 1 Min #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:50.640 | GCJ5.COMEX [CV] 1 Min #10 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:51.163 | CLJ5.NYMEX [CV] #11 | Reloading chart.
2025-03-05 10:22:51.163 | CLJ5.NYMEX [CV] #11 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:51.163 | CLJ5.NYMEX [CV] #11 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:51.243 | GCJ5.COMEX [CV] 1 Min #12 | Reloading chart.
2025-03-05 10:22:51.243 | GCJ5.COMEX [CV] 1 Min #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:22:51.243 | GCJ5.COMEX [CV] 1 Min #12 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:22:51.265 | CLJ5.NYMEX [CV-D] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:22:51.346 | CLJ5.NYMEX [CV-D] 5 Min #2 | Chart data loading complete.
2025-03-05 10:22:51.351 | CLJ5.NYMEX [CV-D] 5 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:22:51.810 | CLJ5.NYMEX [CV-D] 5 Sec #3 | Chart data loading complete.
2025-03-05 10:22:51.829 | CLJ5.NYMEX [CV-D] 1 Min #8 | Chart data loading complete.
2025-03-05 10:22:51.832 | CLJ5.NYMEX [CV-D] 2 Min #5 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:22:51.916 | CLJ5.NYMEX [CV-D] 2 Min #5 | Chart data loading complete.
2025-03-05 10:22:51.924 | GCJ5.COMEX [CV-D] #4 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:22:51.929 | GCJ5.COMEX [CV-D] #4 | Chart data loading complete.
2025-03-05 10:22:51.938 | GCJ5.COMEX [CV-D] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:22:52.021 | GCJ5.COMEX [CV-D] 5 Min #1 | Chart data loading complete.
2025-03-05 10:22:52.025 | GCJ5.COMEX [CV-D] 5 Sec #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:22:52.729 | GCJ5.COMEX [CV-D] 5 Sec #6 | Chart data loading complete.
2025-03-05 10:22:52.742 | GCJ5.COMEX [CV-D] 1 Min #10 | Chart data loading complete.
2025-03-05 10:22:52.745 | CLJ5.NYMEX [CV-D] 1 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:22:52.899 | CLJ5.NYMEX [CV-D] 1 Min #7 | Chart data loading complete.
2025-03-05 10:22:52.910 | GCJ5.COMEX [CV-D] 2 Min #9 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:22:52.978 | GCJ5.COMEX [CV-D] 2 Min #9 | Chart data loading complete.
2025-03-05 10:22:52.978 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:22:52.978 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:22:52.978 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:22:52.979 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:22:52.979 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:22:52.979 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:22:52.986 | CLJ5.NYMEX [CV-D] #11 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:22:52.991 | CLJ5.NYMEX [CV-D] #11 | Chart data loading complete.
2025-03-05 10:22:54.385 | GCJ5.COMEX [CV-D] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:22:54.546 | GCJ5.COMEX [CV-D] 1 Min #12 | Chart data loading complete.
2025-03-05 10:22:54.554 | Rithmic Direct - DTC | Starting real-time market data updates for: CLJ5.NYMEX. ID: 12
2025-03-05 10:22:54.554 | Rithmic Direct - DTC | Requesting security definition data for: CLJ5.NYMEX. ID: 12
2025-03-05 10:22:54.554 | Requesting market depth updates for: CLJ5.NYMEX if supported. NumLevels=1400
2025-03-05 10:22:54.554 | Separate subscription for market depth updates not supported. CLJ5.NYMEX
2025-03-05 10:22:54.554 | Rithmic Direct - DTC | Starting real-time market data updates for: GCJ5.COMEX. ID: 13
2025-03-05 10:22:54.554 | Rithmic Direct - DTC | Requesting security definition data for: GCJ5.COMEX. ID: 13
2025-03-05 10:22:54.554 | Requesting market depth updates for: GCJ5.COMEX if supported. NumLevels=1400
2025-03-05 10:22:54.554 | Separate subscription for market depth updates not supported. GCJ5.COMEX
2025-03-05 10:22:54.565 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:22:54.565 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:22:54.565 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:22:54.565 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:02.269 | Created process D:\SierraChart2\SierraChartInstance_2\SierraChart_64.exe. Current folder: D:\SierraChart2\SierraChartInstance_2
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:02.430 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:02.603 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:02.716 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:02.716 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:02.716 | DTC Client socket (2) | Max send buffers used during socket life: 3
2025-03-05 10:23:02.716 | DTC Client socket (2) | Max send buffer size during socket life: 2671
2025-03-05 10:23:02.716 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:23:02.716 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:02.717 | DTC Client socket (2) | Closed.
2025-03-05 10:23:02.717 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:02.717 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:02.717 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:03.732 | CLJ5.NYMEX [CV-D] 5 Sec #3 | Reloading chart.
2025-03-05 10:23:03.732 | CLJ5.NYMEX [CV-D] 5 Sec #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:23:03.732 | CLJ5.NYMEX [CV-D] 5 Sec #3 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:23:03.741 | Added historical Intraday data request for GCJ5.COMEX to the queue.
2025-03-05 10:23:03.741 | Intraday data recording state for symbol GCJ5.COMEX is set to download 'Pending'.
2025-03-05 10:23:03.741 | Triggering next historical data download in queue.
2025-03-05 10:23:03.885 | CLJ5.NYMEX [CV-D] 5 Sec #3 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:23:04.341 | CLJ5.NYMEX [CV-D] 5 Sec #3 | Chart data loading complete.
2025-03-05 10:23:04.761 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:04.761 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:04.761 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:04.762 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:04.762 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:04.762 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:05.444 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:05.444 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:05.444 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:05.444 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:05.503 | GCJ5.COMEX [CV-D] 5 Sec #6 | Reloading chart.
2025-03-05 10:23:05.503 | GCJ5.COMEX [CV-D] 5 Sec #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:23:05.503 | GCJ5.COMEX [CV-D] 5 Sec #6 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:23:05.510 | CLJ5.NYMEX [CV-D] 5 Min #2 | Reloading chart.
2025-03-05 10:23:05.510 | CLJ5.NYMEX [CV-D] 5 Min #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:23:05.510 | CLJ5.NYMEX [CV-D] 5 Min #2 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:23:05.516 | Added historical Intraday data request for CLJ5.NYMEX to the queue.
2025-03-05 10:23:05.516 | Intraday data recording state for symbol CLJ5.NYMEX is set to download 'Pending'.
2025-03-05 10:23:05.516 | Triggering next historical data download in queue.
2025-03-05 10:23:05.576 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:23:05.577 | GCJ5.COMEX [CV-D] 5 Sec #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:23:06.270 | GCJ5.COMEX [CV-D] 5 Sec #6 | Chart data loading complete.
2025-03-05 10:23:06.740 | CLJ5.NYMEX [CV-D] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:23:06.820 | CLJ5.NYMEX [CV-D] 5 Min #2 | Chart data loading complete.
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:06.821 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:06.821 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:06.821 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | New receive buffer size: 0
2025-03-05 10:23:06.821 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Connecting to IP: 216.66.0.130.
2025-03-05 10:23:06.994 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:07.292 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:07.292 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:07.293 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:07.293 | DTC Client socket (2) | Closed.
2025-03-05 10:23:07.294 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:07.294 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:07.294 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:07.398 | CLJ5.NYMEX [CV-D] 1 Min #7 | Reloading chart.
2025-03-05 10:23:07.398 | CLJ5.NYMEX [CV-D] 1 Min #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:23:07.398 | CLJ5.NYMEX [CV-D] 1 Min #7 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:23:07.405 | GCJ5.COMEX [CV-D] 5 Min #1 | Reloading chart.
2025-03-05 10:23:07.405 | GCJ5.COMEX [CV-D] 5 Min #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:23:07.405 | GCJ5.COMEX [CV-D] 5 Min #1 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:23:07.442 | GCJ5.COMEX [CV-D] 1 Min #12 | Reloading chart.
2025-03-05 10:23:07.442 | GCJ5.COMEX [CV-D] 1 Min #12 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart.
2025-03-05 10:23:07.442 | GCJ5.COMEX [CV-D] 1 Min #12 | There are no continuous futures contract symbols. Loading data normally.
2025-03-05 10:23:07.585 | GCJ5.COMEX [CV-D] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:23:07.700 | GCJ5.COMEX [CV-D] 5 Min #1 | Chart data loading complete.
2025-03-05 10:23:07.829 | CLJ5.NYMEX [CV-D] 1 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:23:07.975 | CLJ5.NYMEX [CV-D] 1 Min #7 | Chart data loading complete.
2025-03-05 10:23:07.976 | GCJ5.COMEX [CV-D] 1 Min #12 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:23:08.140 | GCJ5.COMEX [CV-D] 1 Min #12 | Chart data loading complete.
2025-03-05 10:23:08.448 | Rithmic Direct - DTC | Wrote file: D:\SierraChart2\RithmicConnections.json. Size: 81131
2025-03-05 10:23:08.449 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-03-05 10:23:08.826 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | CloseSocket call.
2025-03-05 10:23:08.826 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:08.980 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Socket gracefully closed by remote side.
2025-03-05 10:23:08.980 | HTTPS connection ID:2 to downloads.rithmic.com:443 for request ID:2 (3) | Closed.
2025-03-05 10:23:09.457 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:09.457 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:09.457 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:09.461 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:09.461 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:09.461 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:09.679 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:09.679 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:09.679 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:09.679 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:10.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:10.520 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:10.758 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:10.758 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:10.759 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:10.759 | DTC Client socket (2) | Closed.
2025-03-05 10:23:10.760 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:10.760 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:10.760 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:12.970 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:12.970 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:12.970 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:12.970 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:12.970 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:12.970 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:13.498 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:13.498 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:13.498 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:13.498 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:14.347 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:14.600 | DTC Protocol server | Incoming connection from 127.0.0.1.
2025-03-05 10:23:14.600 | DTC client #1. 127.0.0.1 (3) | Creating socket.
2025-03-05 10:23:14.600 | DTC client #1. 127.0.0.1 (3) | New receive buffer size: 262144
2025-03-05 10:23:14.601 | DTC client #1. 127.0.0.1 (3) | Allocated send buffers: 32 of 131072 bytes.
2025-03-05 10:23:14.601 | DTC client #1. 127.0.0.1 | Set DTC encoding to Binary VLS
2025-03-05 10:23:14.611 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:15.037 | DTC client #1. 127.0.0.1 | Requested heartbeat interval: 20
2025-03-05 10:23:15.037 | DTC client #1. Sierra Chart. 127.0.0.1 | Received logon request.
2025-03-05 10:23:15.037 | DTC client #1. Sierra Chart. 127.0.0.1 | Sent successful Logon response message to client. Username: lovelivelaught. Result text: Connected to SC DTC Protocol server. Service=rithmic_v2.trading|SymbolSettings=rithmic_v2.trading
2025-03-05 10:23:15.037 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:15.037 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:15.037 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:15.037 | DTC Client socket (2) | Closed.
2025-03-05 10:23:15.039 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:15.039 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:15.039 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:17.034 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:17.034 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:17.034 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:17.034 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:17.034 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:17.034 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:17.367 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:17.367 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:17.367 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:17.367 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:18.653 | HD Request # 1 | Downloading Intraday chart data for BOIL to the file BOIL.scid. Service: rithmic_v2.trading
2025-03-05 10:23:18.653 | HD Request # 1 | Download start date-time: 2025-03-05 10:02:43.000000. File last date-time: 2025-03-05 10:02:43.593000
2025-03-05 10:23:18.653 | HD Request # 1 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:18.653 | Socket (4) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:18.653 | Socket (4) | New receive buffer size: 0
2025-03-05 10:23:18.653 | Socket (4) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:18.829 | HD Request # 1 | Sending historical data logon request message.
2025-03-05 10:23:19.355 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:43. Record interval: 0. Symbol: BOIL
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:19.357 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:19.529 | Socket (4) | CloseSocket call.
2025-03-05 10:23:19.529 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:19.628 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:19.704 | Socket (4) | Socket gracefully closed by remote side.
2025-03-05 10:23:19.704 | Socket (4) | Closed.
2025-03-05 10:23:20.033 | HD Request # 1 | Error downloading historical Intraday data for BOIL. Exchange not specified
2025-03-05 10:23:20.033 | Historical data download thread signaled to stop.
2025-03-05 10:23:20.033 | HD Request # 1 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for BOIL
2025-03-05 10:23:20.033 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:43.593000
2025-03-05 10:23:20.033 | HD Request # 1 | Completion time: 2s.
2025-03-05 10:23:20.033 | HD Request # 1 | Intraday data download complete for BOIL. Unique request ID: 1
2025-03-05 10:23:20.033 | Removing historical data download ID 1.
2025-03-05 10:23:20.033 | Real-time Intraday chart data file updates started for BOIL
2025-03-05 10:23:20.033 | Intraday chart data file opened for BOIL
2025-03-05 10:23:20.033 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:20.033 | Triggering next historical data download in queue.
2025-03-05 10:23:20.033 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:20.033 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:20.034 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:23:20.034 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:20.034 | DTC Client socket (2) | Closed.
2025-03-05 10:23:20.034 | HD Request # 2 | Downloading Intraday chart data for FAS to the file FAS.scid. Service: rithmic_v2.trading
2025-03-05 10:23:20.035 | HD Request # 2 | Download start date-time: 2025-03-05 10:02:48.000000. File last date-time: 2025-03-05 10:02:48.409000
2025-03-05 10:23:20.035 | HD Request # 2 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:20.035 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:20.035 | Socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:20.035 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:20.035 | Socket (2) | New receive buffer size: 0
2025-03-05 10:23:20.035 | Socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:20.040 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:20.299 | HD Request # 2 | Sending historical data logon request message.
2025-03-05 10:23:21.123 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:48. Record interval: 0. Symbol: FAS
2025-03-05 10:23:21.382 | Socket (2) | CloseSocket call.
2025-03-05 10:23:21.382 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:21.597 | HD Request # 2 | Error downloading historical Intraday data for FAS. Exchange not specified
2025-03-05 10:23:21.597 | Historical data download thread signaled to stop.
2025-03-05 10:23:21.597 | HD Request # 2 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for FAS
2025-03-05 10:23:21.598 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:48.409000
2025-03-05 10:23:21.598 | HD Request # 2 | Completion time: 1s.
2025-03-05 10:23:21.598 | HD Request # 2 | Intraday data download complete for FAS. Unique request ID: 2
2025-03-05 10:23:21.598 | Removing historical data download ID 2.
2025-03-05 10:23:21.598 | Real-time Intraday chart data file updates started for FAS
2025-03-05 10:23:21.598 | Intraday chart data file opened for FAS
2025-03-05 10:23:21.598 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:21.598 | Triggering next historical data download in queue.
2025-03-05 10:23:21.598 | HD Request # 3 | Downloading Intraday chart data for GUSH to the file GUSH.scid. Service: rithmic_v2.trading
2025-03-05 10:23:21.598 | HD Request # 3 | Download start date-time: 2025-03-05 10:02:50.000000. File last date-time: 2025-03-05 10:02:50.182000
2025-03-05 10:23:21.598 | HD Request # 3 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:21.598 | Socket (4) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:21.598 | Socket (4) | New receive buffer size: 0
2025-03-05 10:23:21.598 | Socket (4) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:21.639 | Socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:21.639 | Socket (2) | Closed.
2025-03-05 10:23:21.868 | HD Request # 3 | Sending historical data logon request message.
2025-03-05 10:23:22.148 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:22.148 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:22.148 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:22.148 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:22.148 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:22.148 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:22.644 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:22.644 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:22.644 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:22.644 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:23.413 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:50. Record interval: 0. Symbol: GUSH
2025-03-05 10:23:23.436 | DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol CLJ5.NYMEX
2025-03-05 10:23:23.436 | DTC client #1. Sierra Chart. 127.0.0.1 | Received subscribe to market depth for symbol GCJ5.COMEX
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:23.438 | Added historical Intraday data request for BOIL to the queue.
2025-03-05 10:23:23.438 | Intraday data recording state for symbol BOIL is set to download 'Pending'.
2025-03-05 10:23:23.438 | Triggering next historical data download in queue.
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:23.438 | Added historical Intraday data request for FAS to the queue.
2025-03-05 10:23:23.438 | Intraday data recording state for symbol FAS is set to download 'Pending'.
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:23.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:23.532 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:23:23.681 | Socket (4) | CloseSocket call.
2025-03-05 10:23:23.681 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:23.690 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:23.947 | HD Request # 3 | Error downloading historical Intraday data for GUSH. Exchange not specified
2025-03-05 10:23:23.947 | Historical data download thread signaled to stop.
2025-03-05 10:23:23.947 | HD Request # 3 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for GUSH
2025-03-05 10:23:23.947 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:50.182000
2025-03-05 10:23:23.947 | HD Request # 3 | Completion time: 2s.
2025-03-05 10:23:23.947 | HD Request # 3 | Intraday data download complete for GUSH. Unique request ID: 3
2025-03-05 10:23:23.947 | Removing historical data download ID 3.
2025-03-05 10:23:23.947 | Real-time Intraday chart data file updates started for GUSH
2025-03-05 10:23:23.947 | Intraday chart data file opened for GUSH
2025-03-05 10:23:23.947 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:23.947 | Triggering next historical data download in queue.
2025-03-05 10:23:23.947 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:23.947 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:23.948 | DTC Client socket (2) | Max send buffers used during socket life: 3
2025-03-05 10:23:23.948 | DTC Client socket (2) | Max send buffer size during socket life: 2671
2025-03-05 10:23:23.948 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:23:23.948 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:23.948 | DTC Client socket (2) | Closed.
2025-03-05 10:23:23.948 | HD Request # 4 | Downloading Intraday chart data for ICLN to the file ICLN.scid. Service: rithmic_v2.trading
2025-03-05 10:23:23.949 | HD Request # 4 | Download start date-time: 2025-03-05 10:02:44.000000. File last date-time: 2025-03-05 10:02:44.430000
2025-03-05 10:23:23.949 | HD Request # 4 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:23.949 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:23.949 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:23.949 | Socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:23.949 | Socket (2) | New receive buffer size: 0
2025-03-05 10:23:23.949 | Socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:23.953 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:24.205 | HD Request # 4 | Sending historical data logon request message.
2025-03-05 10:23:24.693 | Socket (4) | Socket gracefully closed by remote side.
2025-03-05 10:23:24.693 | Socket (4) | Closed.
2025-03-05 10:23:25.288 | HD Request # 4 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:44. Record interval: 0. Symbol: ICLN
2025-03-05 10:23:25.544 | Socket (2) | CloseSocket call.
2025-03-05 10:23:25.544 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:25.797 | Socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:25.797 | Socket (2) | Closed.
2025-03-05 10:23:26.208 | HD Request # 4 | Error downloading historical Intraday data for ICLN. Exchange not specified
2025-03-05 10:23:26.208 | Historical data download thread signaled to stop.
2025-03-05 10:23:26.208 | HD Request # 4 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for ICLN
2025-03-05 10:23:26.208 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:44.430000
2025-03-05 10:23:26.208 | HD Request # 4 | Completion time: 3s.
2025-03-05 10:23:26.208 | HD Request # 4 | Intraday data download complete for ICLN. Unique request ID: 4
2025-03-05 10:23:26.208 | Removing historical data download ID 4.
2025-03-05 10:23:26.208 | Real-time Intraday chart data file updates started for ICLN
2025-03-05 10:23:26.208 | Intraday chart data file opened for ICLN
2025-03-05 10:23:26.208 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:26.208 | Triggering next historical data download in queue.
2025-03-05 10:23:26.209 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:26.209 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:26.209 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:26.209 | HD Request # 5 | Downloading Intraday chart data for LABU to the file LABU.scid. Service: rithmic_v2.trading
2025-03-05 10:23:26.209 | HD Request # 5 | Download start date-time: 2025-03-05 10:02:49.000000. File last date-time: 2025-03-05 10:02:49.230001
2025-03-05 10:23:26.209 | HD Request # 5 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:26.209 | Socket (4) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:26.209 | Socket (4) | New receive buffer size: 0
2025-03-05 10:23:26.209 | Socket (4) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:26.435 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:26.435 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:26.435 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:26.457 | HD Request # 5 | Sending historical data logon request message.
2025-03-05 10:23:26.810 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:26.810 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:26.810 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:26.810 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:27.205 | HD Request # 5 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:49. Record interval: 0. Symbol: LABU
2025-03-05 10:23:27.452 | Socket (4) | CloseSocket call.
2025-03-05 10:23:27.452 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:27.546 | HD Request # 5 | Error downloading historical Intraday data for LABU. Exchange not specified
2025-03-05 10:23:27.546 | Historical data download thread signaled to stop.
2025-03-05 10:23:27.546 | HD Request # 5 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for LABU
2025-03-05 10:23:27.546 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:49.230001
2025-03-05 10:23:27.546 | HD Request # 5 | Completion time: 1s.
2025-03-05 10:23:27.546 | HD Request # 5 | Intraday data download complete for LABU. Unique request ID: 5
2025-03-05 10:23:27.546 | Removing historical data download ID 5.
2025-03-05 10:23:27.546 | Real-time Intraday chart data file updates started for LABU
2025-03-05 10:23:27.546 | Intraday chart data file opened for LABU
2025-03-05 10:23:27.546 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:27.546 | Triggering next historical data download in queue.
2025-03-05 10:23:27.546 | HD Request # 6 | Downloading Intraday chart data for LIT to the file LIT.scid. Service: rithmic_v2.trading
2025-03-05 10:23:27.546 | HD Request # 6 | Download start date-time: 2025-03-05 10:02:27.000000. File last date-time: 2025-03-05 10:02:27.384000
2025-03-05 10:23:27.546 | HD Request # 6 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:27.546 | Socket (5) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:27.546 | Socket (5) | New receive buffer size: 0
2025-03-05 10:23:27.546 | Socket (5) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:27.697 | Socket (4) | Socket gracefully closed by remote side.
2025-03-05 10:23:27.697 | Socket (4) | Closed.
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:27.701 | Added historical Intraday data request for GUSH to the queue.
2025-03-05 10:23:27.701 | Intraday data recording state for symbol GUSH is set to download 'Pending'.
2025-03-05 10:23:27.701 | Triggering next historical data download in queue.
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:27.701 | Added historical Intraday data request for ICLN to the queue.
2025-03-05 10:23:27.701 | Intraday data recording state for symbol ICLN is set to download 'Pending'.
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:27.701 | Added historical Intraday data request for LABU to the queue.
2025-03-05 10:23:27.701 | Intraday data recording state for symbol LABU is set to download 'Pending'.
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:27.701 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:27.718 | HD Request # 6 | Sending historical data logon request message.
2025-03-05 10:23:27.951 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:28.235 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:27. Record interval: 0. Symbol: LIT
2025-03-05 10:23:28.329 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:28.329 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:28.330 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:23:28.330 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:28.330 | DTC Client socket (2) | Closed.
2025-03-05 10:23:28.331 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:28.331 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:28.331 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:28.407 | Socket (5) | CloseSocket call.
2025-03-05 10:23:28.407 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:28.441 | HD Request # 6 | Error downloading historical Intraday data for LIT. Exchange not specified
2025-03-05 10:23:28.441 | Historical data download thread signaled to stop.
2025-03-05 10:23:28.441 | HD Request # 6 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for LIT
2025-03-05 10:23:28.442 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:27.384000
2025-03-05 10:23:28.442 | HD Request # 6 | Completion time: 1s.
2025-03-05 10:23:28.442 | HD Request # 6 | Intraday data download complete for LIT. Unique request ID: 6
2025-03-05 10:23:28.442 | Removing historical data download ID 6.
2025-03-05 10:23:28.442 | Real-time Intraday chart data file updates started for LIT
2025-03-05 10:23:28.442 | Intraday chart data file opened for LIT
2025-03-05 10:23:28.442 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:28.442 | Triggering next historical data download in queue.
2025-03-05 10:23:28.442 | HD Request # 7 | Downloading Intraday chart data for NUGT to the file NUGT.scid. Service: rithmic_v2.trading
2025-03-05 10:23:28.442 | HD Request # 7 | Download start date-time: 2025-03-05 10:02:47.000000. File last date-time: 2025-03-05 10:02:47.700000
2025-03-05 10:23:28.442 | HD Request # 7 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:28.442 | Socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:28.442 | Socket (2) | New receive buffer size: 0
2025-03-05 10:23:28.442 | Socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:28.579 | Socket (5) | Socket gracefully closed by remote side.
2025-03-05 10:23:28.579 | Socket (5) | Closed.
2025-03-05 10:23:28.678 | HD Request # 7 | Sending historical data logon request message.
2025-03-05 10:23:29.417 | HD Request # 7 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:47. Record interval: 0. Symbol: NUGT
2025-03-05 10:23:29.675 | Socket (2) | CloseSocket call.
2025-03-05 10:23:29.675 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:29.782 | HD Request # 7 | Error downloading historical Intraday data for NUGT. Exchange not specified
2025-03-05 10:23:29.782 | Historical data download thread signaled to stop.
2025-03-05 10:23:29.782 | HD Request # 7 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for NUGT
2025-03-05 10:23:29.782 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:47.700000
2025-03-05 10:23:29.782 | HD Request # 7 | Completion time: 1s.
2025-03-05 10:23:29.782 | HD Request # 7 | Intraday data download complete for NUGT. Unique request ID: 7
2025-03-05 10:23:29.782 | Removing historical data download ID 7.
2025-03-05 10:23:29.782 | Real-time Intraday chart data file updates started for NUGT
2025-03-05 10:23:29.782 | Intraday chart data file opened for NUGT
2025-03-05 10:23:29.782 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:29.782 | Triggering next historical data download in queue.
2025-03-05 10:23:29.783 | HD Request # 8 | Downloading Intraday chart data for SOXL to the file SOXL.scid. Service: rithmic_v2.trading
2025-03-05 10:23:29.783 | HD Request # 8 | Download start date-time: 2025-03-05 10:02:54.000000. File last date-time: 2025-03-05 10:02:54.628000
2025-03-05 10:23:29.783 | HD Request # 8 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:29.783 | Socket (4) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:29.783 | Socket (4) | New receive buffer size: 0
2025-03-05 10:23:29.783 | Socket (4) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:29.926 | Socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:29.926 | Socket (2) | Closed.
2025-03-05 10:23:30.039 | HD Request # 8 | Sending historical data logon request message.
2025-03-05 10:23:30.557 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:30.557 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:30.557 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:30.557 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:30.557 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:30.557 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:30.807 | HD Request # 8 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:54. Record interval: 0. Symbol: SOXL
2025-03-05 10:23:31.060 | Socket (4) | CloseSocket call.
2025-03-05 10:23:31.060 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:31.121 | HD Request # 8 | Error downloading historical Intraday data for SOXL. Exchange not specified
2025-03-05 10:23:31.121 | Historical data download thread signaled to stop.
2025-03-05 10:23:31.121 | HD Request # 8 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for SOXL
2025-03-05 10:23:31.122 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:54.628000
2025-03-05 10:23:31.122 | HD Request # 8 | Completion time: 2s.
2025-03-05 10:23:31.122 | HD Request # 8 | Intraday data download complete for SOXL. Unique request ID: 8
2025-03-05 10:23:31.122 | Removing historical data download ID 8.
2025-03-05 10:23:31.122 | Real-time Intraday chart data file updates started for SOXL
2025-03-05 10:23:31.122 | Intraday chart data file opened for SOXL
2025-03-05 10:23:31.122 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:31.122 | Triggering next historical data download in queue.
2025-03-05 10:23:31.122 | HD Request # 9 | Downloading Intraday chart data for SPXL to the file SPXL.scid. Service: rithmic_v2.trading
2025-03-05 10:23:31.122 | HD Request # 9 | Download start date-time: 2025-03-05 10:02:54.000000. File last date-time: 2025-03-05 10:02:54.063000
2025-03-05 10:23:31.122 | HD Request # 9 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:31.122 | Socket (5) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:31.122 | Socket (5) | New receive buffer size: 0
2025-03-05 10:23:31.122 | Socket (5) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:31.298 | HD Request # 9 | Sending historical data logon request message.
2025-03-05 10:23:31.324 | Socket (4) | Socket gracefully closed by remote side.
2025-03-05 10:23:31.324 | Socket (4) | Closed.
2025-03-05 10:23:31.815 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:54. Record interval: 0. Symbol: SPXL
2025-03-05 10:23:31.987 | Socket (5) | CloseSocket call.
2025-03-05 10:23:31.987 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:32.051 | HD Request # 9 | Error downloading historical Intraday data for SPXL. Exchange not specified
2025-03-05 10:23:32.051 | Historical data download thread signaled to stop.
2025-03-05 10:23:32.051 | HD Request # 9 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for SPXL
2025-03-05 10:23:32.051 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:54.063000
2025-03-05 10:23:32.051 | HD Request # 9 | Completion time: 1s.
2025-03-05 10:23:32.051 | HD Request # 9 | Intraday data download complete for SPXL. Unique request ID: 9
2025-03-05 10:23:32.051 | Removing historical data download ID 9.
2025-03-05 10:23:32.051 | Real-time Intraday chart data file updates started for SPXL
2025-03-05 10:23:32.051 | Intraday chart data file opened for SPXL
2025-03-05 10:23:32.051 | HD Request # 9 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:32.051 | Triggering next historical data download in queue.
2025-03-05 10:23:32.051 | HD Request # 10 | Downloading Intraday chart data for TECL to the file TECL.scid. Service: rithmic_v2.trading
2025-03-05 10:23:32.052 | HD Request # 10 | Download start date-time: 2025-03-05 10:02:50.000000. File last date-time: 2025-03-05 10:02:50.767000
2025-03-05 10:23:32.052 | HD Request # 10 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:32.052 | Socket (4) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:32.052 | Socket (4) | New receive buffer size: 0
2025-03-05 10:23:32.052 | Socket (4) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:32.159 | Socket (5) | Socket gracefully closed by remote side.
2025-03-05 10:23:32.159 | Socket (5) | Closed.
2025-03-05 10:23:32.288 | HD Request # 10 | Sending historical data logon request message.
2025-03-05 10:23:33.014 | HD Request # 10 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:50. Record interval: 0. Symbol: TECL
2025-03-05 10:23:33.241 | Socket (4) | CloseSocket call.
2025-03-05 10:23:33.241 | Socket (4) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:33.332 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:33.332 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:33.332 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:33.332 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:33.332 | HD Request # 10 | Error downloading historical Intraday data for TECL. Exchange not specified
2025-03-05 10:23:33.332 | Historical data download thread signaled to stop.
2025-03-05 10:23:33.332 | HD Request # 10 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for TECL
2025-03-05 10:23:33.333 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:50.767000
2025-03-05 10:23:33.333 | HD Request # 10 | Completion time: 1s.
2025-03-05 10:23:33.333 | HD Request # 10 | Intraday data download complete for TECL. Unique request ID: 10
2025-03-05 10:23:33.333 | Removing historical data download ID 10.
2025-03-05 10:23:33.333 | Real-time Intraday chart data file updates started for TECL
2025-03-05 10:23:33.333 | Intraday chart data file opened for TECL
2025-03-05 10:23:33.333 | HD Request # 10 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:33.333 | Triggering next historical data download in queue.
2025-03-05 10:23:33.333 | HD Request # 11 | Downloading Intraday chart data for TNA to the file TNA.scid. Service: rithmic_v2.trading
2025-03-05 10:23:33.333 | HD Request # 11 | Download start date-time: 2025-03-05 10:02:54.000000. File last date-time: 2025-03-05 10:02:54.729000
2025-03-05 10:23:33.333 | HD Request # 11 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:33.333 | Socket (5) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:33.334 | Socket (5) | New receive buffer size: 0
2025-03-05 10:23:33.334 | Socket (5) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:33.492 | Socket (4) | Socket gracefully closed by remote side.
2025-03-05 10:23:33.492 | Socket (4) | Closed.
2025-03-05 10:23:33.601 | HD Request # 11 | Sending historical data logon request message.
2025-03-05 10:23:34.358 | HD Request # 11 | Requesting Intraday data. Start date-time: 2025-03-05 10:02:54. Record interval: 0. Symbol: TNA
2025-03-05 10:23:34.611 | Socket (5) | CloseSocket call.
2025-03-05 10:23:34.611 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-03-05 10:23:34.859 | Socket (5) | Socket gracefully closed by remote side.
2025-03-05 10:23:34.859 | Socket (5) | Closed.
2025-03-05 10:23:34.941 | HD Request # 11 | Error downloading historical Intraday data for TNA. Exchange not specified
2025-03-05 10:23:34.941 | Historical data download thread signaled to stop.
2025-03-05 10:23:34.941 | HD Request # 11 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for TNA
2025-03-05 10:23:34.941 | HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2025-03-05 17:02:54.729000
2025-03-05 10:23:34.941 | HD Request # 11 | Completion time: 1s.
2025-03-05 10:23:34.941 | HD Request # 11 | Intraday data download complete for TNA. Unique request ID: 11
2025-03-05 10:23:34.941 | Removing historical data download ID 11.
2025-03-05 10:23:34.941 | Real-time Intraday chart data file updates started for TNA
2025-03-05 10:23:34.941 | Intraday chart data file opened for TNA
2025-03-05 10:23:34.941 | HD Request # 11 | Enabling Intraday chart updating for symbol.
2025-03-05 10:23:34.941 | Triggering next historical data download in queue.
2025-03-05 10:23:34.943 | HD Request # 12 | Downloading Intraday chart data for GCJ5.COMEX to the file GCJ5.COMEX.scid. Service: rithmic_v2.trading
2025-03-05 10:23:34.943 | HD Request # 12 | Download start date-time: 2025-03-05 10:07:25.000000. File last date-time: 2025-03-05 10:07:25.000001
2025-03-05 10:23:34.943 | HD Request # 12 | Using server: rsc.rithmic.com port 50502. Use encryption.
2025-03-05 10:23:34.943 | Socket (4) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:34.944 | Socket (4) | New receive buffer size: 0
2025-03-05 10:23:34.944 | Socket (4) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:35.003 | HD Server Manager | Incoming connection from IP: 127.0.0.1
2025-03-05 10:23:35.003 | HD Server Manager | Started new historical data server. Count=1
2025-03-05 10:23:35.022 | HD Server | Thread:17344 (5) | Creating socket.
2025-03-05 10:23:35.023 | HD Server | Thread:17344 (5) | New receive buffer size: 262144
2025-03-05 10:23:35.023 | HD Server | Thread:17344 (5) | Allocated send buffers: 32 of 4096 bytes.
2025-03-05 10:23:35.023 | HD Server | Setting DTC encoding to Binary VLS | Thread:17344
2025-03-05 10:23:35.026 | HD Server | Received login. Requesting authorization. | Username: lovelivelaught. | Thread:17344
2025-03-05 10:23:35.026 | HD Server | Login has been authorized. | Username: lovelivelaught. | Thread:17344
2025-03-05 10:23:35.030 | HD Server | HD Request #12 | Socket: 5 | Symbol: CLG5.NYMEX | ServiceCode: DTCSubInstance | RecordInterval: 0 | MaximumDaysRequested: 0 | Start date-time: 2025-02-20 23:59:59 | ClientReqID: 12 | Username: lovelivelaught. | Thread:17344
2025-03-05 10:23:35.030 | Added historical Intraday data request for CLG5.NYMEX to the queue.
2025-03-05 10:23:35.030 | Triggering next historical data download in queue.
2025-03-05 10:23:35.195 | HD Request # 12 | Sending historical data logon request message.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:35.576 | Added historical Intraday data request for LIT to the queue.
2025-03-05 10:23:35.576 | Intraday data recording state for symbol LIT is set to download 'Pending'.
2025-03-05 10:23:35.576 | Triggering next historical data download in queue.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:35.576 | Added historical Intraday data request for NUGT to the queue.
2025-03-05 10:23:35.576 | Intraday data recording state for symbol NUGT is set to download 'Pending'.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:35.576 | Added historical Intraday data request for SOXL to the queue.
2025-03-05 10:23:35.576 | Intraday data recording state for symbol SOXL is set to download 'Pending'.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:35.576 | Added historical Intraday data request for SPXL to the queue.
2025-03-05 10:23:35.576 | Intraday data recording state for symbol SPXL is set to download 'Pending'.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:35.576 | Added historical Intraday data request for TECL to the queue.
2025-03-05 10:23:35.576 | Intraday data recording state for symbol TECL is set to download 'Pending'.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:35.576 | Added historical Intraday data request for TNA to the queue.
2025-03-05 10:23:35.576 | Intraday data recording state for symbol TNA is set to download 'Pending'.
2025-03-05 10:23:35.576 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:35.837 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:35.837 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:35.837 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:35.838 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:23:35.838 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:35.838 | DTC Client socket (2) | Closed.
2025-03-05 10:23:35.838 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:35.838 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:35.838 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:35.944 | HD Request # 12 | Requesting Intraday data. Start date-time: 2025-03-05 10:07:25. Record interval: 0. Symbol: GCJ5.COMEX
2025-03-05 10:23:36.208 | HD Request # 12 | Receiving Intraday data for GCJ5.COMEX starting at 2025-03-05 10:07:25.512000
2025-03-05 10:23:37.844 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:37.844 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:37.844 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:37.844 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:37.844 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:37.844 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:38.088 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:38.088 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:38.088 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:38.088 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:38.854 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:39.111 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:39.111 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:39.111 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:39.111 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:39.111 | DTC Client socket (2) | Closed.
2025-03-05 10:23:39.111 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:39.111 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:39.111 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:41.105 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:41.105 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:41.105 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:41.110 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:41.110 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:41.110 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:41.298 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:41.298 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:41.298 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:41.298 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:41.550 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:41.912 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:42.103 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:42.104 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:42.104 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:42.104 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:42.104 | DTC Client socket (2) | Closed.
2025-03-05 10:23:42.105 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:42.105 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:42.105 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:44.104 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:44.104 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:44.104 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:44.105 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:44.105 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:44.105 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:44.366 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:44.366 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:44.366 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:44.366 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:46.773 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:47.023 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:47.023 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2025-03-05 10:23:47.023 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:47.023 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:47.023 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:47.023 | DTC Client socket (2) | Closed.
2025-03-05 10:23:47.023 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:47.023 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:47.023 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:49.017 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:49.017 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:49.017 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:49.017 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:49.017 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:49.017 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:49.203 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:49.203 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:49.203 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:49.203 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:49.771 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:49.957 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:49.957 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:49.957 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:49.958 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:49.958 | DTC Client socket (2) | Closed.
2025-03-05 10:23:49.958 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:49.958 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:49.958 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:51.957 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:51.957 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:51.957 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:51.958 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:51.958 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:51.958 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:52.181 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:52.181 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:52.181 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:52.181 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:52.910 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:53.169 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:53.169 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:53.169 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:53.169 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:23:53.169 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:53.169 | DTC Client socket (2) | Closed.
2025-03-05 10:23:53.169 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:53.169 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:53.169 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:55.176 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:55.176 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:55.176 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:55.176 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:55.176 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:55.176 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:55.433 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:55.433 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:55.433 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:55.433 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:56.190 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:56.438 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:56.438 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:56.438 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:56.439 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:56.439 | DTC Client socket (2) | Closed.
2025-03-05 10:23:56.439 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:56.439 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:56.439 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:23:58.445 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:23:58.445 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:23:58.445 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:23:58.445 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:23:58.445 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:23:58.445 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:23:58.694 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:23:58.694 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:23:58.694 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:23:58.694 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:23:59.455 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:23:59.548 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:23:59.702 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:23:59.703 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:23:59.703 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:23:59.703 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:23:59.703 | DTC Client socket (2) | Closed.
2025-03-05 10:23:59.703 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:23:59.703 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:23:59.703 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:01.699 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:01.699 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:01.699 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:01.699 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:01.699 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:01.699 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:01.936 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:01.936 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:01.936 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:01.936 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:02.692 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:02.940 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:02.940 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:02.940 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:02.941 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:02.941 | DTC Client socket (2) | Closed.
2025-03-05 10:24:02.941 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:02.941 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:02.941 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:04.946 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:04.946 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:04.946 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:04.947 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:04.947 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:04.947 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:06.212 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:06.212 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:06.212 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:06.212 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:07.758 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:08.029 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:08.029 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:08.029 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:08.029 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:08.029 | DTC Client socket (2) | Closed.
2025-03-05 10:24:08.029 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:08.029 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:08.029 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:10.036 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:10.036 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:10.036 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:10.036 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:10.036 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:10.036 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:10.281 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:10.281 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:10.281 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:10.281 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:11.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:11.297 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:11.297 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:11.297 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:11.297 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:11.297 | DTC Client socket (2) | Closed.
2025-03-05 10:24:11.297 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:11.297 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:11.297 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:13.306 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:13.306 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:13.306 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:13.306 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:13.306 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:13.306 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:13.478 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:13.478 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:13.478 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:13.478 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:14.002 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:14.175 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:14.175 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:14.175 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:14.176 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:24:14.176 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:14.176 | DTC Client socket (2) | Closed.
2025-03-05 10:24:14.176 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:14.176 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:14.176 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:16.180 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:16.180 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:16.180 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:16.180 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:16.180 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:16.180 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:16.430 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:16.430 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:16.430 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:16.430 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:17.226 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:17.484 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:17.485 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:17.485 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:17.485 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:17.485 | DTC Client socket (2) | Closed.
2025-03-05 10:24:17.485 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:17.485 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:17.485 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:17.533 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:24:19.480 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:19.480 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:19.480 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:19.480 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:19.480 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:19.480 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:19.698 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:19.698 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:19.698 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:19.698 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:20.401 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:20.402 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:20.402 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:20.402 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:20.402 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:20.402 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:20.402 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:20.402 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:20.623 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:20.623 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:20.623 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:20.623 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:20.623 | DTC Client socket (2) | Closed.
2025-03-05 10:24:20.623 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:20.623 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:20.623 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:22.634 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:22.634 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:22.634 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:22.634 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:22.634 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:22.634 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:22.804 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:22.804 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:22.804 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:22.804 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:23.775 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:23.960 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:24.013 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:24.013 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:24.013 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:24.013 | DTC Client socket (2) | Closed.
2025-03-05 10:24:24.013 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:24.013 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:24.014 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:26.127 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:26.127 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:26.127 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:26.127 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:26.127 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:26.127 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:26.382 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:26.382 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:26.382 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:26.382 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:27.418 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:27.664 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:27.677 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:27.677 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:27.677 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:27.677 | DTC Client socket (2) | Closed.
2025-03-05 10:24:27.677 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:27.677 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:27.677 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:30.249 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:30.249 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:30.249 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:30.254 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:30.254 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:30.254 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:30.473 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:30.473 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:30.473 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:30.473 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:31.017 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:31.188 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:31.654 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:31.654 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:31.655 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:31.655 | DTC Client socket (2) | Closed.
2025-03-05 10:24:31.655 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:31.655 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:31.655 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:33.673 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:33.673 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:33.673 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:33.674 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:33.674 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:33.674 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:34.296 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:34.296 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:34.296 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:34.296 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:35.042 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:35.042 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:35.042 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:35.042 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:35.042 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:35.042 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:35.042 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:35.043 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:35.214 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:35.660 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:35.660 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:35.660 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:24:35.660 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:35.660 | DTC Client socket (2) | Closed.
2025-03-05 10:24:35.661 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:24:35.661 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:35.661 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:35.661 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:37.709 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:37.709 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:37.709 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:37.710 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:37.710 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:37.710 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:38.033 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:38.033 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:38.033 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:38.033 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:39.144 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:39.405 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:39.488 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:39.488 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:39.488 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:24:39.488 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:39.488 | DTC Client socket (2) | Closed.
2025-03-05 10:24:39.489 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:39.489 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:39.489 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:41.587 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:41.587 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:41.587 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:41.587 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:41.588 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:41.588 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:41.872 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:41.872 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:41.872 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:41.872 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:42.438 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:42.461 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 2.
2025-03-05 10:24:42.610 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:43.076 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:43.076 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:43.077 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:43.077 | DTC Client socket (2) | Closed.
2025-03-05 10:24:43.078 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:43.078 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:43.078 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:43.699 | Symbol settings received. Request ID: 2.
2025-03-05 10:24:43.700 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:43.700 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:43.762 | Rithmic Direct - DTC | Waiting for socket receive thread to end
2025-03-05 10:24:43.762 | DTC Client socket (1) | CloseSocket call.
2025-03-05 10:24:43.762 | DTC Client socket (1) | Max send buffers used during socket life: 3
2025-03-05 10:24:43.762 | DTC Client socket (1) | Max send buffer size during socket life: 406
2025-03-05 10:24:43.762 | Rithmic Direct - DTC | Disconnected.
2025-03-05 10:24:43.762 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-03-05 10:24:43.762 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-03-05 10:24:44.007 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-03-05 10:24:44.007 | DTC Client socket (1) | Closed.
2025-03-05 10:24:47.792 |
2025-03-05 10:24:47.792 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:47.792 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:47.792 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500
2025-03-05 10:24:47.797 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:47.797 | DTC Client socket (1) | New receive buffer size: 0
2025-03-05 10:24:47.797 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:48.158 | Rithmic Direct - DTC | Network connection to server complete.
2025-03-05 10:24:48.158 | Rithmic Direct - DTC | Starting socket receive thread.
2025-03-05 10:24:48.158 | Rithmic Direct - DTC | Setting DTC encoding to Binary
2025-03-05 10:24:48.158 | Rithmic Direct - DTC | Sending logon request message.
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | Received logon response.
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | Server Name: .
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | Successfully connected.
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | Trading is supported.
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | Order cancel and replace is supported.
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | OCO Orders supported.
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | Symbol and Exchange Delimiter: .
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | MarketDepthIsSupported: 0
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | Connected to server complete.
2025-03-05 10:24:48.959 | No download requests in the queue to start downloads for.
2025-03-05 10:24:48.959 | Triggering next historical data download in queue.
2025-03-05 10:24:48.959 | No download requests in the queue to start downloads for. | Number times message added: 1
2025-03-05 10:24:48.959 | Using symbol data fast lookup vector
2025-03-05 10:24:48.959 | Rithmic Direct - DTC | Starting real-time market data updates for: BOIL. ID: 1
2025-03-05 10:24:48.964 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: BOIL. ID: 1
2025-03-05 10:24:48.964 | Intraday data recording state for symbol BOIL is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for BOIL is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Starting real-time market data updates for: FAS. ID: 2
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: FAS. ID: 2
2025-03-05 10:24:48.964 | Intraday data recording state for symbol FAS is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for FAS is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Starting real-time market data updates for: GUSH. ID: 3
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: GUSH. ID: 3
2025-03-05 10:24:48.964 | Intraday data recording state for symbol GUSH is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for GUSH is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Starting real-time market data updates for: ICLN. ID: 4
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: ICLN. ID: 4
2025-03-05 10:24:48.964 | Intraday data recording state for symbol ICLN is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for ICLN is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Starting real-time market data updates for: LABU. ID: 5
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: LABU. ID: 5
2025-03-05 10:24:48.964 | Intraday data recording state for symbol LABU is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for LABU is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Starting real-time market data updates for: LIT. ID: 6
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: LIT. ID: 6
2025-03-05 10:24:48.964 | Intraday data recording state for symbol LIT is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for LIT is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Starting real-time market data updates for: NUGT. ID: 7
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: NUGT. ID: 7
2025-03-05 10:24:48.964 | Intraday data recording state for symbol NUGT is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for NUGT is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Starting real-time market data updates for: SOXL. ID: 8
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: SOXL. ID: 8
2025-03-05 10:24:48.964 | Intraday data recording state for symbol SOXL is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for SOXL is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:48.964 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Starting real-time market data updates for: SPXL. ID: 9
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: SPXL. ID: 9
2025-03-05 10:24:48.964 | Intraday data recording state for symbol SPXL is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for SPXL is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Starting real-time market data updates for: TECL. ID: 10
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: TECL. ID: 10
2025-03-05 10:24:48.964 | Intraday data recording state for symbol TECL is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for TECL is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:48.964 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:48.964 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Starting real-time market data updates for: TNA. ID: 11
2025-03-05 10:24:48.964 | Rithmic Direct - DTC | Requesting security definition data for: TNA. ID: 11
2025-03-05 10:24:48.964 | Intraday data recording state for symbol TNA is set to download 'Pending'.
2025-03-05 10:24:48.964 | Historical Intraday data request, start 00:00:00.000 , for TNA is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:24:49.033 | Rithmic Direct - DTC | Starting real-time market data updates for: GCJ5.COMEX. ID: 12
2025-03-05 10:24:49.033 | Rithmic Direct - DTC | Requesting security definition data for: GCJ5.COMEX. ID: 12
2025-03-05 10:24:49.037 | Rithmic Direct - DTC | Starting real-time market data updates for: CLJ5.NYMEX. ID: 13
2025-03-05 10:24:49.037 | Rithmic Direct - DTC | Requesting security definition data for: CLJ5.NYMEX. ID: 13
2025-03-05 10:24:49.527 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:49.527 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:49.527 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:49.527 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:49.527 | Requesting market depth updates for: CLJ5.NYMEX if supported. NumLevels=1400
2025-03-05 10:24:49.527 | Separate subscription for market depth updates not supported. CLJ5.NYMEX
2025-03-05 10:24:49.527 | Requesting market depth updates for: GCJ5.COMEX if supported. NumLevels=1400
2025-03-05 10:24:49.527 | Separate subscription for market depth updates not supported. GCJ5.COMEX
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:50.495 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:50.667 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:50.694 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:50.694 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:50.695 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:24:50.695 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:50.695 | DTC Client socket (2) | Closed.
2025-03-05 10:24:50.695 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:50.695 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:50.695 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:52.712 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:52.712 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:52.712 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:52.712 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:52.712 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:52.712 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:53.360 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:53.360 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:53.360 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:53.360 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:54.256 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:54.516 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:54.828 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:54.828 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:54.828 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:24:54.828 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:54.828 | DTC Client socket (2) | Closed.
2025-03-05 10:24:54.829 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:54.829 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:54.829 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:24:56.859 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:24:56.859 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:24:56.859 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:24:56.860 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:24:56.860 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:24:56.860 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:24:57.636 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:24:57.636 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:24:57.636 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:24:57.636 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:24:58.284 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:24:58.471 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:24:58.503 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:24:58.503 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:24:58.503 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:24:58.503 | DTC Client socket (2) | Closed.
2025-03-05 10:24:58.503 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:24:58.503 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:24:58.503 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:00.699 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:00.699 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:00.699 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:00.699 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:00.699 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:00.699 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:01.442 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:01.442 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:01.442 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:01.442 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:02.260 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:02.260 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:02.260 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:02.260 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:02.260 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:02.260 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:02.260 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:02.260 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:02.261 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:02.518 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:02.749 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:02.749 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:02.749 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:02.749 | DTC Client socket (2) | Closed.
2025-03-05 10:25:02.749 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:02.749 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:02.749 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:04.827 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:04.827 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:04.827 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:04.828 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:04.828 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:04.828 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:05.034 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:05.034 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:05.034 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:05.034 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:05.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:05.838 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:06.271 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:06.271 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:06.271 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:06.272 | DTC Client socket (2) | Closed.
2025-03-05 10:25:06.272 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:06.272 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:06.272 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:06.890 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:25:07.827 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:07.827 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | New receive buffer size: 0
2025-03-05 10:25:07.827 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Connecting to IP: 216.66.0.130.
2025-03-05 10:25:08.466 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:08.466 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:08.466 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:08.467 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:08.467 | DTC Client socket (6) | New receive buffer size: 0
2025-03-05 10:25:08.467 | DTC Client socket (6) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:09.358 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:09.358 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:09.358 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:09.358 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:09.359 | Rithmic Direct - DTC | Wrote file: D:\SierraChart2\RithmicConnections.json. Size: 81131
2025-03-05 10:25:09.360 | Rithmic Direct - DTC | Processed connection points. Count: 347
2025-03-05 10:25:09.635 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | CloseSocket call.
2025-03-05 10:25:09.635 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Shutdown started. Waiting for graceful close.
2025-03-05 10:25:09.787 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:09.787 | HTTPS connection ID:3 to downloads.rithmic.com:443 for request ID:3 (2) | Closed.
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:10.202 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:10.468 | DTC Client socket (6) | Socket gracefully closed by remote side.
2025-03-05 10:25:10.986 | DTC Client socket (6) | CloseSocket call.
2025-03-05 10:25:10.986 | DTC Client socket (6) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:10.986 | DTC Client socket (6) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:25:10.986 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:10.986 | DTC Client socket (6) | Closed.
2025-03-05 10:25:10.991 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:10.991 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:10.991 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:13.232 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:13.232 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:13.232 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:13.232 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:13.232 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:13.232 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:13.497 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:13.497 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:13.497 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:13.497 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:14.681 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:14.681 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:14.681 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:14.681 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:14.681 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:14.681 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:14.681 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:14.681 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:14.682 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:14.921 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:15.298 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:15.298 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:15.299 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:15.299 | DTC Client socket (2) | Closed.
2025-03-05 10:25:15.299 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:15.299 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:15.299 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:15.333 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 3.
2025-03-05 10:25:16.166 | Symbol settings received. Request ID: 3.
2025-03-05 10:25:16.168 | Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'.
2025-03-05 10:25:17.653 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:17.653 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:17.653 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:17.653 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:17.653 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:17.653 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:17.897 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:17.897 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:17.897 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:17.897 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:18.450 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:18.622 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:19.142 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:19.142 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:19.142 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:25:19.142 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:19.142 | DTC Client socket (2) | Closed.
2025-03-05 10:25:19.144 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:19.144 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:19.144 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:21.229 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:21.229 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:21.229 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:21.230 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:21.230 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:21.230 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:22.631 | CLJ5.NYMEX [CV-D] 1 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-03-05 10:25:23.638 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:23.638 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:23.638 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:23.638 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:25.071 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:25.072 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:25.341 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:25.620 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:25.620 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:25.620 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:25:25.620 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:25.620 | DTC Client socket (2) | Closed.
2025-03-05 10:25:25.622 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:25.622 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:25.622 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:27.704 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:27.704 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:27.704 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:27.705 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:27.705 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:27.705 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:27.963 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:27.963 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:27.963 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:27.963 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:29.290 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:29.290 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:29.290 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:29.290 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:29.290 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:29.290 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:29.290 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:29.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:29.291 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:29.526 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:29.841 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:29.841 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:29.842 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:29.842 | DTC Client socket (2) | Closed.
2025-03-05 10:25:29.842 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:29.842 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:29.842 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:32.115 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:32.115 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:32.115 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:32.115 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:32.115 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:32.115 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:33.557 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:33.557 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:33.557 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:33.557 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:35.033 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:35.034 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:35.034 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:35.034 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:35.034 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:35.034 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:35.034 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:35.034 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:35.259 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:35.455 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:35.455 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:35.455 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:35.455 | DTC Client socket (2) | Closed.
2025-03-05 10:25:35.455 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:35.455 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:35.455 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:37.643 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:37.643 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:37.643 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:37.648 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:37.648 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:37.648 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:38.016 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:38.016 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:38.016 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:38.016 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:39.161 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:39.410 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:39.705 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:39.705 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:39.706 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:25:39.706 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:39.706 | DTC Client socket (2) | Closed.
2025-03-05 10:25:39.706 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:39.706 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:39.706 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:41.905 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:41.905 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:41.905 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:41.905 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:41.905 | DTC Client socket (6) | New receive buffer size: 0
2025-03-05 10:25:41.905 | DTC Client socket (6) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:42.281 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:42.281 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:42.281 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:42.281 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:42.697 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:43.277 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:43.530 | DTC Client socket (6) | Socket gracefully closed by remote side.
2025-03-05 10:25:43.750 | DTC Client socket (6) | CloseSocket call.
2025-03-05 10:25:43.750 | DTC Client socket (6) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:43.750 | DTC Client socket (6) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:25:43.750 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:43.750 | DTC Client socket (6) | Closed.
2025-03-05 10:25:43.751 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:43.751 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:43.751 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:46.050 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:46.050 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:46.050 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:46.051 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:46.051 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:46.051 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:46.270 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:46.270 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:46.270 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:46.270 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:47.359 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:47.529 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:47.742 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:47.742 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:47.743 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:25:47.743 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:47.743 | DTC Client socket (2) | Closed.
2025-03-05 10:25:47.743 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:47.743 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:47.743 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:49.792 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:49.792 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:49.792 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:49.792 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:49.792 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:49.792 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:51.311 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:51.311 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:51.311 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:51.311 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:52.678 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:52.934 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:53.321 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:53.321 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:53.321 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:25:53.321 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:53.321 | DTC Client socket (2) | Closed.
2025-03-05 10:25:53.322 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:53.322 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:53.322 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:55.461 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:55.461 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:55.461 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:55.461 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:55.462 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:55.462 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:25:56.039 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:25:56.039 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:25:56.039 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:25:56.039 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:25:57.061 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:25:57.242 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:25:57.532 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:25:57.532 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:25:57.532 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:25:57.532 | DTC Client socket (2) | Closed.
2025-03-05 10:25:57.534 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:25:57.534 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:25:57.534 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:25:59.743 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:25:59.743 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:25:59.743 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:25:59.743 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:25:59.743 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:25:59.743 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:00.095 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:00.095 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:00.095 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:00.095 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:00.807 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:01.227 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:01.494 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:01.745 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:01.745 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:01.745 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:26:01.745 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:01.745 | DTC Client socket (2) | Closed.
2025-03-05 10:26:01.746 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:01.746 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:01.746 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:03.955 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:03.955 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:03.955 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:03.956 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:03.956 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:03.956 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:04.185 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:04.185 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:04.185 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:04.185 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:05.349 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:05.349 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:05.349 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:05.349 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:05.349 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:05.349 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:05.349 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:05.349 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:05.350 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:05.522 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:05.538 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:05.538 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:05.538 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:05.538 | DTC Client socket (2) | Closed.
2025-03-05 10:26:05.539 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:05.539 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:05.539 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:07.561 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:07.561 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:07.561 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:07.796 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:07.797 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:07.797 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:10.082 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:10.082 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:10.082 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:10.082 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:12.901 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:13.168 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:13.593 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:13.593 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:13.593 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:13.593 | DTC Client socket (2) | Closed.
2025-03-05 10:26:13.594 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:13.594 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:13.594 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:15.630 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:15.630 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:15.630 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:15.631 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:15.631 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:15.631 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:16.168 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:16.168 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:16.168 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:16.168 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:17.012 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:17.012 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:17.012 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:17.012 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:17.012 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:17.012 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:17.012 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:17.012 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:17.013 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:17.260 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:17.269 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:17.269 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:17.269 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:17.269 | DTC Client socket (2) | Closed.
2025-03-05 10:26:17.269 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:17.269 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:17.269 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:18.900 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:26:19.374 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:19.374 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:19.374 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:19.374 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:19.374 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:19.374 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:20.167 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:20.167 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:20.167 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:20.167 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:20.578 | Requested symbol settings for service code rithmic_v2.trading. Request ID: 4.
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:21.249 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:21.420 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:21.472 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:21.472 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:21.473 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:26:21.473 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:21.473 | DTC Client socket (2) | Closed.
2025-03-05 10:26:21.473 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:21.473 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:21.473 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:22.161 | Symbol settings received. Request ID: 4.
2025-03-05 10:26:22.163 | Reconnect to the data feed after processing symbol settings. Use 'File >> Disconnect' and 'File >> Connect to Data Feed'.
2025-03-05 10:26:23.491 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:23.491 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:23.491 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:23.495 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:23.495 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:23.495 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:23.688 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:23.688 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:23.688 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:23.688 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:24.482 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:24.483 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:24.483 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:24.483 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:24.656 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:24.796 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:24.796 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:24.797 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:24.797 | DTC Client socket (2) | Closed.
2025-03-05 10:26:24.797 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:24.797 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:24.797 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:27.082 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:27.082 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:27.082 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:27.083 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:27.083 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:27.083 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:27.375 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:27.375 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:27.375 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:27.375 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:28.612 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:28.883 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:29.073 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:29.073 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:29.073 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:29.073 | DTC Client socket (2) | Closed.
2025-03-05 10:26:29.074 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:29.074 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:29.074 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:31.336 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:31.336 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:31.336 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:31.336 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:31.336 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:31.336 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:32.203 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:32.203 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:32.203 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:32.203 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:33.557 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:33.825 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:34.133 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:34.133 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:34.133 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:26:34.133 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:34.133 | DTC Client socket (2) | Closed.
2025-03-05 10:26:34.133 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:34.133 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:34.133 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:36.193 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:36.193 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:36.193 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:36.193 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:36.193 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:36.193 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:36.415 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:36.415 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:36.415 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:36.415 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:36.878 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:37.625 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:37.797 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:37.854 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:37.854 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:37.855 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:26:37.855 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:37.855 | DTC Client socket (2) | Closed.
2025-03-05 10:26:37.855 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:37.855 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:37.855 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:40.445 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:40.445 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:40.445 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:40.445 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:40.446 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:40.446 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:41.088 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:41.088 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:41.088 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:41.088 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:41.913 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:42.174 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:42.285 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:42.285 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:42.285 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:42.285 | DTC Client socket (2) | Closed.
2025-03-05 10:26:42.286 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:42.286 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:42.286 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:44.429 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:44.429 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:44.429 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:44.429 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:44.429 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:44.429 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:44.691 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:44.691 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:44.692 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:44.692 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:46.344 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:46.344 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:46.344 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:46.344 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:46.344 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:46.344 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:46.344 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:46.345 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:46.611 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:47.042 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:47.042 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:47.043 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:47.043 | DTC Client socket (2) | Closed.
2025-03-05 10:26:47.043 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:47.044 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:47.044 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:49.127 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:49.127 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:49.127 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:49.128 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:49.128 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:49.128 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:51.431 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:51.431 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:51.431 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:51.431 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:53.669 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:53.954 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:54.417 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:54.417 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:54.417 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:26:54.417 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:54.417 | DTC Client socket (2) | Closed.
2025-03-05 10:26:54.418 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:54.418 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:54.418 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:26:54.978 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:26:56.568 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:26:56.568 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:26:56.568 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:26:56.573 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:26:56.573 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:26:56.573 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:26:57.284 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:26:57.284 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:26:57.284 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:26:57.284 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:26:57.932 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:26:58.107 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:26:58.608 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:26:58.608 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:26:58.609 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:26:58.609 | DTC Client socket (2) | Closed.
2025-03-05 10:26:58.609 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:26:58.609 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:26:58.609 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:27:00.621 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:27:00.621 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:27:00.621 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:27:00.621 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:27:00.621 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:27:00.621 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:27:01.309 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:27:01.309 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:27:01.309 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:27:01.309 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:27:01.847 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:27:02.033 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:27:02.536 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:27:02.536 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:27:02.537 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:27:02.537 | DTC Client socket (2) | Closed.
2025-03-05 10:27:02.537 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:27:02.537 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:27:02.537 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:27:04.564 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:27:04.564 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:27:04.564 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:27:04.564 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:27:04.564 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:27:04.564 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:27:05.209 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:27:05.209 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:27:05.209 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:27:05.209 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:27:06.508 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:27:06.781 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:27:07.163 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:27:07.163 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:27:07.163 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:27:07.163 | DTC Client socket (2) | Closed.
2025-03-05 10:27:07.164 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:27:07.164 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:27:07.164 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:27:09.357 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:27:09.357 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:27:09.357 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:27:09.357 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:27:09.357 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:27:09.357 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:27:09.616 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:27:09.616 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:27:09.616 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:27:09.616 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:27:10.619 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:27:10.795 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:27:10.823 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:27:10.823 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:27:10.823 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:27:10.823 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:27:10.823 | DTC Client socket (2) | Closed.
2025-03-05 10:27:10.823 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:27:10.823 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:27:10.823 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:27:12.723 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:27:13.338 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:27:13.338 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:27:13.338 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:27:13.343 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:27:13.343 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:27:13.343 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:27:13.967 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:27:13.967 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:27:13.967 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:27:13.967 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:27:14.867 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:27:15.139 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:27:15.435 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:27:15.435 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:27:15.436 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:27:15.436 | DTC Client socket (2) | Closed.
2025-03-05 10:27:15.436 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:27:15.436 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:27:15.436 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:27:17.658 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:27:17.658 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:27:17.658 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:27:17.658 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:27:17.658 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:27:17.658 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:27:18.496 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:27:18.496 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:27:18.496 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:27:18.496 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:27:19.434 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:27:19.691 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:27:19.744 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:27:19.744 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:27:19.744 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:27:19.744 | DTC Client socket (2) | Closed.
2025-03-05 10:27:19.744 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:27:19.744 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:27:19.744 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:27:21.847 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:27:21.847 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:27:21.847 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:27:21.847 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:27:21.847 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:27:21.847 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:27:22.532 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:27:22.532 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:27:22.532 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:27:22.532 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:27:25.078 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:27:30.852 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:27:46.480 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2025-03-05 10:27:46.480 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:27:46.543 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:27:46.543 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:27:46.543 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:27:46.543 | DTC Client socket (2) | Closed.
2025-03-05 10:27:46.543 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:27:46.543 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:27:46.543 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:27:48.546 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:27:48.546 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:27:48.546 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:27:48.546 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:27:48.547 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:27:48.547 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:27:48.908 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:27:48.908 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:27:48.908 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:27:48.908 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:27:48.908 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:27:49.541 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:27:49.541 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:27:49.541 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:27:49.541 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:27:49.541 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:27:49.541 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:27:49.541 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:27:49.542 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:27:49.716 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:27:49.730 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:27:49.730 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:27:49.731 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:27:49.731 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:27:49.731 | DTC Client socket (2) | Closed.
2025-03-05 10:27:49.731 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:27:49.731 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:27:49.731 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:27:52.318 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:27:52.318 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:27:52.318 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:27:52.318 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:27:52.319 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:27:52.319 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:27:52.820 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:27:52.820 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:27:52.821 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:27:52.821 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:27:53.665 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:27:53.665 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:27:53.665 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:27:53.665 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:27:53.665 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:27:53.665 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:27:53.665 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:27:53.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:27:53.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:27:53.665 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:27:53.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:27:53.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:27:53.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:27:53.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:27:53.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:27:53.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:27:53.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:27:53.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:27:53.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:27:53.666 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:27:53.837 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:27:53.886 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:27:53.886 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:27:53.887 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:27:53.887 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:27:53.887 | DTC Client socket (2) | Closed.
2025-03-05 10:27:53.887 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:27:53.887 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:27:53.887 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:27:56.427 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:27:56.427 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:27:56.427 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:27:56.427 | DTC Client socket (6) | Creating socket. Using TLS 1.2.
2025-03-05 10:27:56.427 | DTC Client socket (6) | New receive buffer size: 0
2025-03-05 10:27:56.427 | DTC Client socket (6) | Connecting to IP: 216.57.156.163.
2025-03-05 10:27:56.963 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:27:56.963 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:27:56.963 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:27:56.963 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:27:57.863 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:27:58.113 | DTC Client socket (6) | Socket gracefully closed by remote side.
2025-03-05 10:27:58.134 | DTC Client socket (6) | CloseSocket call.
2025-03-05 10:27:58.134 | DTC Client socket (6) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:27:58.135 | DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:27:58.135 | DTC Client socket (6) | Closed.
2025-03-05 10:27:58.135 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:27:58.135 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:27:58.135 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:00.622 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:00.622 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:00.622 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:00.626 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:00.627 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:00.627 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:00.916 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:00.916 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:00.916 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:00.916 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:02.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:02.823 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:02.841 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:02.841 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:02.842 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:28:02.842 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:02.842 | DTC Client socket (2) | Closed.
2025-03-05 10:28:02.842 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:02.842 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:02.842 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:04.981 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:04.981 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:04.981 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:04.982 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:04.982 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:04.982 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:05.512 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:05.512 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:05.512 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:05.512 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:06.377 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:06.552 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:06.780 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:06.780 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:06.780 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:28:06.780 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:06.780 | DTC Client socket (2) | Closed.
2025-03-05 10:28:06.780 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:28:06.780 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:06.780 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:06.781 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:09.415 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:09.415 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:09.415 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:09.415 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:09.415 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:09.415 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:09.737 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:09.737 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:09.737 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:09.737 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:10.290 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:10.463 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:11.116 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:11.116 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:11.117 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:11.117 | DTC Client socket (2) | Closed.
2025-03-05 10:28:11.118 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:11.118 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:11.118 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:13.120 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:13.120 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:13.120 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:13.121 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:13.121 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:13.121 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:13.424 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:13.424 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:13.424 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:13.424 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:14.555 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:14.844 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:15.197 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:15.197 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:15.198 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:15.198 | DTC Client socket (2) | Closed.
2025-03-05 10:28:15.198 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:15.198 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:15.198 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:17.237 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:17.237 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:17.237 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:17.241 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:17.241 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:17.241 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:18.642 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:18.642 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:18.642 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:18.642 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:20.628 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:20.628 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:20.628 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:20.628 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:20.628 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:20.628 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:20.628 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:20.629 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:20.899 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:21.084 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:21.084 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:21.085 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:21.085 | DTC Client socket (2) | Closed.
2025-03-05 10:28:21.085 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:21.085 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:21.085 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:23.198 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:23.198 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:23.198 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:23.198 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:23.199 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:23.199 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:23.547 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:23.547 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:23.547 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:23.547 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:24.657 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:24.719 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:28:24.924 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:25.126 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:25.126 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:25.126 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:25.126 | DTC Client socket (2) | Closed.
2025-03-05 10:28:25.126 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:25.126 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:25.126 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:27.234 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:27.234 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:27.234 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:27.234 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:27.235 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:27.235 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:27.450 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:27.450 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:27.450 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:27.450 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:27.979 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:28.160 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:28.700 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:28.700 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:28.700 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:28.700 | DTC Client socket (2) | Closed.
2025-03-05 10:28:28.700 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:28.700 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:28.700 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:31.089 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:31.089 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:31.089 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:31.089 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:31.089 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:31.089 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:31.492 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:31.492 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:31.493 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:31.493 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:34.580 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:34.856 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:35.531 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:35.531 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:35.531 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:28:35.531 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:35.531 | DTC Client socket (2) | Closed.
2025-03-05 10:28:35.532 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:35.532 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:35.532 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:37.543 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:37.543 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:37.543 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:37.543 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:37.543 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:37.543 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:38.183 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:38.183 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:38.183 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:38.183 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:38.927 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:39.115 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:39.530 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:39.530 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:39.531 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:39.531 | DTC Client socket (2) | Closed.
2025-03-05 10:28:39.531 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:39.531 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:39.531 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:41.556 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:41.556 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:41.556 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:41.556 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:41.556 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:41.556 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:42.462 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:42.462 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:42.462 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:42.462 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:42.776 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:44.109 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:44.386 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:44.646 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:44.646 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:44.646 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:44.646 | DTC Client socket (2) | Closed.
2025-03-05 10:28:44.646 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:44.646 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:44.646 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:46.886 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:46.886 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:46.886 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:46.887 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:46.887 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:46.887 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:47.509 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:47.509 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:47.509 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:47.509 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:48.403 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:48.661 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:49.064 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:49.064 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:49.065 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:49.065 | DTC Client socket (2) | Closed.
2025-03-05 10:28:49.066 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:49.066 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:49.066 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:51.351 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:51.351 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:51.351 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:51.356 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:51.356 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:51.356 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:51.737 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:51.737 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:51.737 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:51.737 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:52.623 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:52.794 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:52.811 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:52.811 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:52.812 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:52.812 | DTC Client socket (2) | Closed.
2025-03-05 10:28:52.812 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:52.812 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:52.812 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:54.858 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:54.859 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:54.859 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:54.859 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:54.859 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:54.859 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:28:55.588 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:28:55.588 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:28:55.588 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:28:55.588 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:28:56.373 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:28:56.623 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:28:56.956 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:28:56.956 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:28:56.956 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:28:56.956 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:28:56.956 | DTC Client socket (2) | Closed.
2025-03-05 10:28:56.957 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:28:56.957 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:28:56.957 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:28:59.263 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:28:59.263 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:28:59.263 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:28:59.264 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:28:59.265 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:28:59.265 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:00.073 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:00.073 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:00.073 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:00.073 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:00.883 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:00.885 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:01.144 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:01.707 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:01.707 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:01.707 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:01.707 | DTC Client socket (2) | Closed.
2025-03-05 10:29:01.707 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:01.707 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:01.707 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:03.716 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:03.716 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:03.716 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:03.717 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:03.717 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:03.717 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:04.326 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:04.326 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:04.326 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:04.326 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:04.947 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:05.120 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:05.559 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:05.559 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:05.559 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:05.559 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:05.559 | DTC Client socket (2) | Closed.
2025-03-05 10:29:05.560 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:05.560 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:05.560 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:07.638 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:07.638 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:07.638 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:07.638 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:07.639 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:07.639 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:08.312 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:08.312 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:08.312 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:08.312 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:08.987 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:09.159 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:09.540 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:09.540 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:09.540 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:09.540 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:09.540 | DTC Client socket (2) | Closed.
2025-03-05 10:29:09.540 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:09.540 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:09.540 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:11.592 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:11.592 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:11.592 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:11.592 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:11.592 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:11.592 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:12.270 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:12.270 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:12.271 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:12.271 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:13.616 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:13.869 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:13.910 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:13.910 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:13.911 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:13.911 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:13.911 | DTC Client socket (2) | Closed.
2025-03-05 10:29:13.912 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:13.912 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:13.912 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:16.420 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:16.420 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:16.420 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:16.420 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:16.420 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:16.420 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:16.646 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:16.646 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:16.646 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:16.646 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:17.208 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:17.380 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:17.798 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:17.798 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:17.798 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:17.798 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:17.798 | DTC Client socket (2) | Closed.
2025-03-05 10:29:17.799 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:17.799 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:17.799 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:18.783 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:29:19.875 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:19.875 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:19.875 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:19.876 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:19.876 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:19.876 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:20.204 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:20.204 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:20.204 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:20.204 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:21.040 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:21.300 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:21.443 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:21.443 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:21.444 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:21.444 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:21.444 | DTC Client socket (2) | Closed.
2025-03-05 10:29:21.444 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:21.444 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:21.444 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:23.608 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:23.608 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:23.608 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:23.609 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:23.609 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:23.609 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:23.803 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:23.803 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:23.803 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:23.803 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:24.352 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:24.524 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:24.923 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:24.923 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:24.923 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:24.923 | DTC Client socket (2) | Closed.
2025-03-05 10:29:24.924 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:24.924 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:24.924 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:27.127 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:27.127 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:27.127 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:27.128 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:27.128 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:27.128 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:27.767 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:27.767 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:27.768 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:27.768 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:28.497 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:28.669 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:28.682 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:28.682 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:28.682 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:28.682 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:28.682 | DTC Client socket (2) | Closed.
2025-03-05 10:29:28.682 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:28.683 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:28.683 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:30.699 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:30.699 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:30.699 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:30.703 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:30.704 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:30.704 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:31.180 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:31.180 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:31.180 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:31.180 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:32.005 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:32.006 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:32.272 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:32.363 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:32.363 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:32.363 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:32.363 | DTC Client socket (2) | Closed.
2025-03-05 10:29:32.363 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:32.363 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:32.363 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:34.378 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:34.378 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:34.378 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:34.378 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:34.378 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:34.378 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:34.616 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:34.616 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:34.616 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:34.616 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:35.466 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:35.638 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:35.655 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:35.655 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:35.655 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:35.655 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:35.655 | DTC Client socket (2) | Closed.
2025-03-05 10:29:35.655 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:35.655 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:35.655 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:36.851 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:29:38.313 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:38.313 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:38.313 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:38.314 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:38.314 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:38.314 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:38.591 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:38.591 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:38.591 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:38.591 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:39.732 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:39.995 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:40.035 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:40.035 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:40.035 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:40.035 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:40.035 | DTC Client socket (2) | Closed.
2025-03-05 10:29:40.035 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:40.035 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:40.035 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:42.131 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:42.131 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:42.131 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:42.132 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:42.132 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:42.132 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:42.722 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:42.722 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:42.722 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:42.722 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:43.545 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:43.803 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:44.219 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:44.219 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:44.220 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:44.220 | DTC Client socket (2) | Closed.
2025-03-05 10:29:44.221 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:44.221 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:44.221 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:46.285 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:46.285 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:46.285 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:46.289 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:46.289 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:46.289 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:46.979 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:46.979 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:46.979 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:46.979 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:47.838 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:47.845 | Intraday data recording state for symbol CLJ5.NYMEX is set to download 'Pending'.
2025-03-05 10:29:47.845 | Historical Intraday data request, start 00:00:00.000 , for CLJ5.NYMEX is discarded because a matching download is already pending and the new one is not for earlier data.
2025-03-05 10:29:48.082 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:48.427 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:48.427 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:48.428 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:48.428 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:48.428 | DTC Client socket (2) | Closed.
2025-03-05 10:29:48.428 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:48.428 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:48.428 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:50.470 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:50.470 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:50.470 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:50.471 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:50.471 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:50.471 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:50.653 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:50.653 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:50.653 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:50.653 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:51.321 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:51.493 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:51.667 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:51.667 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:51.667 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:51.667 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:51.667 | DTC Client socket (2) | Closed.
2025-03-05 10:29:51.668 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:51.668 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:51.668 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:53.907 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:53.907 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:53.907 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:53.908 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:53.908 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:53.908 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:54.236 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:54.236 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:54.236 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:54.236 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:54.783 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:55.480 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:55.749 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:55.943 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:55.943 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:55.944 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:55.944 | DTC Client socket (2) | Closed.
2025-03-05 10:29:55.944 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:55.944 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:55.945 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:29:58.142 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:29:58.142 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:29:58.142 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:29:58.143 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:29:58.143 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:29:58.143 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:29:58.316 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:29:58.316 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:29:58.316 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:29:58.316 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:29:58.933 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:29:59.105 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:29:59.582 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:29:59.582 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:29:59.582 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:29:59.582 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:29:59.582 | DTC Client socket (2) | Closed.
2025-03-05 10:29:59.582 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:29:59.582 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:29:59.583 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:30:01.575 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:30:01.575 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:30:01.575 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:30:01.580 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:30:01.580 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:30:01.580 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:30:02.874 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:30:02.874 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:30:02.874 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:30:02.874 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:30:03.654 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:30:03.909 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:30:04.313 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:30:04.313 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:30:04.314 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:30:04.314 | DTC Client socket (2) | Closed.
2025-03-05 10:30:04.314 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:30:04.314 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:30:04.314 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:30:06.446 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:30:06.446 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:30:06.446 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:30:06.446 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:30:06.446 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:30:06.446 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:30:07.205 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:30:07.205 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:30:07.205 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:30:07.205 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:30:07.860 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:30:07.860 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:30:07.860 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:30:07.860 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:30:07.860 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:30:07.860 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:30:07.860 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:30:07.861 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:30:08.033 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:30:08.612 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:30:08.612 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:30:08.612 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:30:08.612 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:30:08.613 | DTC Client socket (2) | Closed.
2025-03-05 10:30:08.613 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:30:08.613 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:30:08.613 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:30:10.631 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:30:10.631 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:30:10.631 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:30:10.631 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:30:10.632 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:30:10.632 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:30:11.351 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:30:11.351 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:30:11.351 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:30:11.351 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:30:12.811 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:30:12.812 | Rithmic Direct - DTC | Heartbeat from server , ServerReceivedClientHeartbeatSecondsAgo=0, NumberOfOutstandingSendBuffers=0, TransmissionDelayInMilliseconds=0, ServerSendBufferSizeInBytes=0, ActualMessageDelay=0.0 seconds, DataCompRatio=0.00, UncompressedBytes=0, CompressionTime=0.000000(secs), NumCompressions=0, Source=0.0.0.0
2025-03-05 10:30:13.065 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:30:13.297 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:30:13.297 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:30:13.297 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:30:13.297 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:30:13.297 | DTC Client socket (2) | Closed.
2025-03-05 10:30:13.299 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:30:13.299 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:30:13.299 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:30:15.322 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:30:15.322 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:30:15.322 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:30:15.322 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:30:15.322 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:30:15.322 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:30:15.580 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:30:15.580 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:30:15.580 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:30:15.580 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:30:17.412 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:30:17.942 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2025-03-05 10:30:17.942 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:30:18.469 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:30:18.469 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:30:18.469 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:30:18.469 | DTC Client socket (2) | Closed.
2025-03-05 10:30:18.470 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:30:18.470 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:30:18.470 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:30:20.613 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:30:20.613 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:30:20.613 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:30:20.614 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:30:20.614 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:30:20.614 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:30:21.327 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:30:21.327 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:30:21.327 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:30:21.327 | Rithmic Direct - DTC (Data) | Sending logon request message.
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Received logon response.
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Server Name: .
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Server protocol version: 8. Client protocol version: 8
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Successfully connected.
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Trading is not supported.
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Symbol and Exchange Delimiter: .
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | MarketDepthIsSupported: 1
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: BOIL
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: CLJ5.NYMEX. Market Depth data restarted.
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: FAS
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GCJ5.COMEX. Market Depth data restarted.
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: GUSH
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: ICLN
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LABU
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: LIT
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: NUGT
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SOXL
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: SPXL
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TECL
2025-03-05 10:30:22.157 | Rithmic Direct - DTC (Data) | Restarting real-time data updates for symbol: TNA
2025-03-05 10:30:22.328 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-03-05 10:30:22.907 | DTC Client socket (2) | CloseSocket call.
2025-03-05 10:30:22.907 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2025-03-05 10:30:22.907 | DTC Client socket (2) | Shutdown error. Windows error code 10054: An existing connection was forcibly closed by the remote host. *
2025-03-05 10:30:22.907 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2025-03-05 10:30:22.907 | DTC Client socket (2) | Closed.
2025-03-05 10:30:22.909 | DTC Client socket (0) | CloseSocket call.
2025-03-05 10:30:22.909 | Rithmic Direct - DTC (Data) | Disconnected from the server.
2025-03-05 10:30:22.909 | Rithmic Direct - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds.
2025-03-05 10:30:24.948 | Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated
2025-03-05 10:30:24.948 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50500
2025-03-05 10:30:24.948 | Rithmic Direct - DTC (Data) | Connecting to the server rsc.rithmic.com. Port 50501
2025-03-05 10:30:24.949 | DTC Client socket (2) | Creating socket. Using TLS 1.2.
2025-03-05 10:30:24.949 | DTC Client socket (2) | New receive buffer size: 0
2025-03-05 10:30:24.949 | DTC Client socket (2) | Connecting to IP: 216.57.156.163.
2025-03-05 10:30:25.613 | Rithmic Direct - DTC (Data) | Network connection to server complete.
2025-03-05 10:30:25.613 | Rithmic Direct - DTC (Data) | Starting socket receive thread.
2025-03-05 10:30:25.613 | Rithmic Direct - DTC (Data) | Setting DTC encoding to Binary
2025-03-05 10:30:25.613 | Rithmic Direct - DTC (Data) | Sending logon request message.
[2025-03-05 19:32:33]
John - SC Support - Posts: 47164
You have symbols that Rithmic does not like. Refer to the following:
Rithmic Trading Platform Service: Frequent Reconnections
[2025-03-06 02:23:14]
lovelivelaught - Posts: 94
I removed some symbols from data files but few of them stuck to the files and after I tried to remove them multiple times they were always coming back. I have no idea where they are coming from. I attached a screenshot of these symbols. How can I remove them?
imageScreenshot 2025-03-06 075147.png / V - Attached On 2025-03-06 02:18:50 UTC - Size: 34.44 KB - 140 views
[2025-03-06 15:41:46]
You do not need to remove the actual files from the 'Data' folder.
But, if the files keep showing up, then there is something in the Sierra Chart instance that is requesting that data. You need to go through the items as mentioned at the following link:
[2025-03-07 01:15:01]
That is a thing I do not have any Associated Watch Lists, Quote Boards, and Symbol Alerts and I manually updated Intraday File List.
This week is all i have been doing is to improve the connection and I have done so much to improve it but the data is still going with a delay up to 2 sec, with long intervals to update and every time i place an order it takes additional 2 sec to process it.
I have now two identical platforms with identical settings set up and with Rithmic connections on each but Bulenox Rithmic connection is noticeably slow. Is this because they are using a Rithmic paper trading connection or what is your thoughts?
[2025-03-07 14:20:29]
A data delay of 2 seconds could be due to your computer clock being off versus the exchange. This is typically nothing to be concerned about. But refer to the following if you want to have Sierra Chart set your computer clock:
Network Time Protocol Client
As to a delay with Rithmic, this is not unusual with Rihtmic. We cannot say that it is related to the paper trading or not, but we can tell you that what you are seeing happens a lot with Rihtmic.
