Date/Time: Mon, 21 Apr 2025 13:08:35 +0000
Installation problem.
View Count: 91
[2025-02-27 11:06:14] |
User247614 - Posts: 2 |
Im trying to install a link to sierra chart resulting telling me installation completed with errors.https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=116054
Attachment Deleted. ![]() |
[2025-02-27 15:49:00] |
John - SC Support - Posts: 39362 |
The error you are getting (Windows Error 32) is stating that the files cannot be moved as they are already in use by another program. Most often, this is caused by having Sierra Chart running while you are trying to update. Please make sure that all instances of Sierra Chart have been closed prior to doing the installation. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
