Date/Time: Mon, 21 Apr 2025 13:11:43 +0000
Chart and Volume Profile
View Count: 79
[2025-02-27 10:54:22] |
Utente315082 - Posts: 1 |
Hello I have a question. I have a graph for example a line timeframe 1 min, I set a Volume Profile to bars and fix it to the right. When the line graph scrolls and arrives on the right it overlaps with the volume profile. How can I stop the scrolling of the graph first so as not to overlap with the volume profile? Thank you very much for your help |
[2025-02-27 15:42:44] |
John - SC Support - Posts: 39362 |
We think you are looking for the "Lock Fill Space" option. Refer to the following: Chart Menu: Lock Fill Space (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
