Date/Time: Fri, 20 Sep 2024 05:51:14 +0000
Study /Price Overlay - Fill Blanks with last value - not working
View Count: 1210
[2014-09-22 18:16:47] |
ertrader - Posts: 668 |
Hi Support, Beginning with Version 1192, "Fill blanks with last value" appears to be ignored. Normally, on the graph below, the purple line would extend to the current price action. Can you please take a look? The only study on this graph is Study/Price Overlay. http://www.sierrachart.com/image.php?l=1411409618650.png Date Time Of Last Edit: 2014-09-22 18:30:27
[2014-09-22 18:23:20] |
Here are the settings: Date Time Of Last Edit: 2014-09-22 18:25:09
Settings.png / V - Attached On 2014-09-22 18:25:03 UTC - Size: 25.12 KB - 360 views |
[2014-09-22 18:27:53] |
A few notes: 1) This graph and the reference graph are not on the same time frame - by design 2) Both this graph and the reference graph are Renko chart types in chart settings 3) This change happened when I upgraded from V1187 to V1192 4) I have tried other settings but nothing seems to help Date Time Of Last Edit: 2014-09-22 18:31:01
[2014-09-22 22:30:26] |
We will be solving this for you today. Thank you for pointing this out. There were some changes to the study and this is an inadvertent problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-24 07:36:41] |
We got behind on this. We are working on this now.
[2014-09-24 09:54:13] |
Update to the latest prerelease. This problem should now be resolved.
