Date/Time: Tue, 15 Apr 2025 12:33:28 +0000
Minor tweak to Rectangles
View Count: 197
[2025-02-26 18:18:43] |
User98657 - Posts: 353 |
I realize in your scope of work this is a VERY minor issue, but hoping it is a very quick fix. I noticed this issue when you draw Rectangles, and/or Extending Rectangles. When you use Text, Draw Midline = Yes, Center Text On Level=Yes, Center Text Vertically=Yes or No, Opaque Label Background = Yes; The Midline will extend through the Text. Even if you don't center Text vertically, but place it in the center of the level, the outline will then run through the text. This doesn't happen with the Price Labels. When you add Price Labels, Opaque Background or not, the lines do not pass through the Price Label. I'm hoping you can easily tweak the Text Label so the lines don't pass through the Text. Thanks as always. |
[2025-02-26 23:51:10] |
Sierra_Chart Engineering - Posts: 19226 |
We will look this over.
[2025-02-26 23:58:09] |
As we were going through this we are not understanding it. There is no text in the midline area. Provide an image of the chart or Trade DOM, by following these *exact* instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-27 00:45:01] |
Please see attached image.https://www.sierrachart.com/image.php?Image=1740617038882.png
[2025-02-28 07:51:12] |
We will solve this in the next release.
[2025-03-11 13:13:43] |
Hello, I updated to the current version this morning, bringing me to 2746. The main page indicates 2746 was released 3/7/25. This issue is still present. Next release I assume? Thanks. |
[2025-04-05 20:49:05] |
Hello, It looks like there have been a few releases since your note that this would be solved in the next release. It appears as though the issue is still the same. Can you please advise? Thanks. |
[2025-04-09 22:12:10] |
Can you provide an update?
[2025-04-10 15:02:43] |
This definitively has been worked nd the midline no longer will draw over the text. Update to the latest version which is 2752. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
