Date/Time: Mon, 21 Apr 2025 13:08:34 +0000
Trailing step and scale in
View Count: 520
[2025-02-26 17:35:38] |
User255408 - Posts: 3 |
Hello, I'm using a Triggered Step Trail Stop and its working fine. But, if I scale in, the trailing stop is still stepping from the 1st opening position price instead of the new average position. There is any option I need to change or it is intended to work this way only? Thank you
[2025-02-26 20:22:54] |
Sierra_Chart Engineering - Posts: 19285 |
We would have to check but this must be how it is designed.
